02-20-2015, 08:30 PM | #21 |
Rock Stacker Join Date: Aug 2007 Location: Ventura, Ca.
| Re: SSD - Wraith Axle Option Parts
That tranny is bad ass and is just what I need to start a Foff build |
02-20-2015, 10:07 PM | #22 |
Pebble Pounder Join Date: Mar 2014 Location: U4IA Oregon
I bought the SSD wraith steering link and its great. It makes the Vanquish version look bad. The SSD link not only looks better it preforms better! I am about to buy another one from RPP right now =)
02-21-2015, 08:52 AM | #23 | |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: SSD - Wraith Axle Option Parts Quote:
I do however like that the SSD supplied hardware is button head for the tie rod ends. Those dam socket heads VP use don't help tire clearence. The SSD product line is looking great. | |
02-21-2015, 11:13 PM | #24 | |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
The only reason I ask is because I know there are some trans forward options that people make and they use the cover holes for mounting up. (I.E. GCMs and Toyzukis) Great products by the way and thank you for making the lower gear two part I cant stand one piece main gears! | |
02-21-2015, 11:48 PM | #25 | |
02-22-2015, 03:59 AM | #26 | |
RCC Addict Join Date: Oct 2014 Location: UK
The SSD transmission case does not have the same mounting points for the motor plate. However the SSD motor plate does have the mounting holes for the stock Axial gear cover. Hope that helps. | |
02-22-2015, 04:17 AM | #27 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| Re: SSD - Wraith Axle Option Parts |
02-22-2015, 04:45 AM | #28 |
02-22-2015, 06:36 AM | #29 |
Pebble Pounder Join Date: Feb 2014 Location: grand forks
Placed my order for the trans for my wraith yesterday can't wait for it to get here
02-22-2015, 02:37 PM | #30 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I ordered a tranny yesterday at work when I saw it under the new products thread. Will I still be able to achieve a good slow crawl ratio with the tranny?
02-22-2015, 05:04 PM | #31 |
What is the output ratio if the tranny compared to stock? I could probably do the math if I counted the teeth on the gears in the pics but my eyes aren't that good anymore!
02-22-2015, 05:21 PM | #32 |
I joined the Band! Join Date: Dec 2014 Location: Earth
02-22-2015, 07:32 PM | #33 |
Quarry Creeper Join Date: Jan 2011 Location: 808 via Reno, Nv.
| Re: SSD - Wraith Axle Option Parts I would also like to know this answer too. Im ready to pull the trigger on one but if it will defeat my purpose of a slow crawler with a 5.8 ratio I use just for rock crawling, well than I cant use this. Unless I buy it just for the bad @ss transmission case. |
02-22-2015, 08:02 PM | #34 |
02-22-2015, 09:39 PM | #35 |
| Re: SSD - Wraith Axle Option Parts It's a lot higher than I would want for a single-speed crawler, but it would be nice as a second gear in a two-speed and for those looking for more speed from their Wraith.
02-23-2015, 02:54 AM | #36 | |
SSD: 1.8:1 stock: 2.6:1 | |
02-23-2015, 06:53 AM | #37 |
Thanks for the response SSD.... I would suggest that you put this info in the first post. Your tranny would appeal to both go fast and trail crowds. I have a few sets of the UD gears so I'm set. Keep up the killer work. Your products are killing it.
02-23-2015, 08:12 AM | #38 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Or go super low on pinion/spur, 64t clears MIPs.... Next project for sure.
02-23-2015, 10:46 AM | #39 |
Pebble Pounder Join Date: Nov 2014 Location: in the woods
I plan on ordering a set of the black 2.2 wheels here in a month or so for my wraith! Beautiful products SSD
02-23-2015, 02:31 PM | #40 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Would also be nice for someone not wanting to run a 2 speed but wanting a faster ratio, run the 43/13 axle gears for a final ratio of 5.95, if you run stock gearing and stock trans, final ratio is 7.59. Options are great now. Wes |
SSD - Wraith Axle Option Parts - Similar Threads | ||||
Rear axle option | Erik D_lux | RC4WD Bully | 6 | 05-14-2015 09:26 AM |
part front& part behind the axle steering | assassin_tl | Venom Creeper | 3 | 11-03-2009 07:49 AM |
TLT Axle Mini Option | Harvo | Newbie General | 2 | 10-10-2008 04:35 PM |
