02-11-2015, 03:18 AM | #21 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Vanquish scale knuckle & steering issue
Ahh yeah, sure ditto that's a 2 way street, like when you assumed lowering the tie rod was suitable for the op driving terrain. |
02-11-2015, 05:09 AM | #22 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Vanquish scale knuckle & steering issue I didn't assume anything. The photo appeared to be a shot of the stock knuckle (minor mistake), the stock knuckles are supposed to have the steering link on the bottom of the steering arms as per the Wraith kit instructions. Despite the fact the Vanquish knuckles are intended to have the link between the double shear arms, mounting it on the bottom would still be the simplest, quickest and most cost effective way to cure his current linkage binding issue. But only if the OP is willing to give up the double shear option, I doubt he is since it's possibly one of the reasons he bought the Vanquish knuckles to begin with. It's still a viable quick-fix option for his current problem whether it's the preferred solution or not.
02-11-2015, 06:29 AM | #23 |
RCC Addict Join Date: Aug 2013 Location: Missoula
The god has spoken. The rods shall be mounted as low as possible. We shall all listen.
02-11-2015, 06:32 AM | #24 | |
| Re: Vanquish scale knuckle & steering issue Quote:
There is always more than one way! That is what makes this hobby so great. To paraphrase something (because I'm dumb and can't remember the exact words) an RCC OG once said. "Give 10 guys the same axles and chassis, and you will end up with 10 different rigs." Last edited by DickyT; 02-11-2015 at 07:47 AM. Reason: fixing auto correct phone spelling. | |
02-11-2015, 07:14 AM | #25 |
Hopefully next time the op will make their thread description clearer, something like "Vanquish scale knuckle & steering issue"
02-11-2015, 07:58 AM | #26 | |
Rock Crawler Join Date: May 2012 Location: Upland
This new free Tapatalk sucks.... | |
02-11-2015, 08:06 AM | #27 | |
In 1:1's, beefed up rigs that only see light duty are called mall crawlers. What would be good name for an trail tough RC that lives the same kind of life? Driveway roamers? | |
02-11-2015, 08:13 AM | #28 | |
Rock Crawler Join Date: Feb 2014 Location: ?
I gotta laugh when I see posts like "it's not worth the trouble to" because all I hear is lazy. It's always worth the trouble to optimize your rig. The more optimized your rig is the larger your e-peen. Everyone knows that. My two cents is to make sure you have your C hubs where you want them and measure and get a clamping horn the fits the gap and have it exactly the way you want. | |
02-11-2015, 08:17 AM | #29 |
most people drive them around their garage floor. So maybe Garage something? idk
02-11-2015, 02:43 PM | #30 |
Newbie Join Date: Oct 2011 Location: Riverside
wow this thread got entertaining quick! lol! I think I have it figured out, as others mentioned A shorter servo horn was nessesary. The pic I posted had the stock horn as mockup only, never inteded to use it. I guess I could have been more clear on that. I used it for mockup because the aluminum clamping horn I picked up was waaayyy to long to fit! I have since drilled and taped a new hole and cut off the bottom of it. I moved the chubs back to the OEM position (although I dont think it matters) and I think it will work out fine! Thanks for the replys and possible build thread names. I dont usually do build threads, however dont be surprised if you see "project carpet muncher" pop up... |
02-11-2015, 03:42 PM | #31 | |
Having the chubs rotated back will have a positive effect on your steering ability due to the positive caster they give. Positive caster angle greatly improves steering performance, the more the better to a point. Last edited by DickyT; 02-11-2015 at 04:35 PM. Reason: maslin corrected my positive\negative blunder | |
02-11-2015, 04:14 PM | #32 |
Positive caster. And yes, more caster is a good thing on these rigs in my experience. |
02-11-2015, 04:29 PM | #33 |
| Re: Vanquish scale knuckle & steering issue |
02-11-2015, 04:35 PM | #34 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
02-11-2015, 04:53 PM | #35 |
| Re: Vanquish scale knuckle & steering issue There will still be something different about each one. Even if each was a green jeep with purple seats and yellow steering wheels, there will be some difference. Wheels, tires, foams, gearing, choice of scale accessories, shocks, the amount of flecks |
02-15-2015, 11:36 PM | #36 |
Quarry Creeper Join Date: Sep 2014 Location: pacific northwest
So are you guys saying if I bought the stage 1 kit, I would have to make modifications to my wraith to make it fit?
02-16-2015, 11:19 AM | #37 |
Rock Stacker Join Date: Jan 2015 Location: LONDON
ugh I hope my set of scale hubs and knuckles don't cause issues. I run VP steering links and trail ready rims (stock poison spyder) anyone run this setup without problems?
02-16-2015, 06:37 PM | #38 |
Newbie Join Date: Dec 2014 Location: ocala
The vanquish hubs are off the chain. There are always issues in modifying any rig. Either 1:1 or 1:10. We buy these to tinker and be creative. Not to be bashed on for a failure to Foresee issues that arise. Solve the problem. Wheel the toy cars and have a blast. I run the vanquish scale Hubs , knuckles, and titanium steering. Only difference is I have a cms. Which causes other clearance issues. The direction that this post went really fast and attacking other posters is why I gave this up 10 years ago. As you can see I am a lurker. been here for 1 year and this is my first post. Oh well back under my rock I go.
03-02-2015, 02:05 AM | #39 |
03-02-2015, 09:20 PM | #40 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Vanquish scale knuckle & steering issue I'm running a vp scale c hubs,knuckles axles and CMS and short servo horn on my Wraith it is the black one. The blue one is my sons Wraith it has CMS vanquish linkages but different vanquish c hubs carriers with a long servo horn. To me this adds more clearance on the servo maybe this will help. Last edited by greengoblin; 03-02-2015 at 09:27 PM. |
Vanquish scale knuckle & steering issue - Similar Threads | ||||
Vanquish Products Hurtz dig shifter issue & the fix. | WIDELOAD | General Crawlers | 5 | 02-27-2016 02:29 AM |
Trouble with vanquish steering knuckle | nedaroth | Axial Wraith | 3 | 07-20-2013 10:14 AM |
scx 10 steering knuckle & 2.2 tires? | Barndog Racing | Newbie General | 9 | 12-31-2012 09:56 AM |
Vanquish Wraith C-Hub & Steering knuckle Video Review & Install | FastEddy | Axial Wraith | 0 | 10-28-2011 01:04 PM |
