![]() | #1 |
Pebble Pounder Join Date: Mar 2015 Location: Fairland
So was out driving my wraith today since it was such a nice day here in the midwest. I got about 5 minutes into it and all the sudden my motor quit working. Still had steering so I unplugged battery and plugged it back in. No beeps from ESC for cell count still no power to motor. Found that the red led still blinks when I apply throttle and stays solid upon full throttle but no motor turn. Tires are free so there is no binding. I am assuming it is smoked. Which axial says that the AE-5 is 3s compatible....so I am at a loss. What do you guys think?
![]() | #2 |
Pebble Pounder Join Date: Feb 2015 Location: East Bay Area, CA
Try to rebind the radio to reciever and then try to recalibrate the esc.
![]() | #3 |
I wanna be Dave ![]() Join Date: Feb 2013 Location: NW Indiana
You may have had a motor failure....does it run with battery applied directly to the motor leads? I would verify the condition of the motor before buying an ESC...was it the stock motor?...
![]() | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Check your motor brushes and the wires to the motor. If the brushes are worn and/or not sliding smoothly in the brush hood you'll loose motor function. Same goes for a motor wire that's not connected securely.
![]() | #5 |
I will try rebinding. The motor works fine. No it is not the stock motor. It is a firebolt. Cheap motor I can abuse and replace if necessary. Brushes look alright about half worn. Yes it runs with battery connected to motor leads. I use a single round cell Lipo to test that. I just found it weird that it doesn't beep anymore to designate how many lipo cells it detects.
![]() | #6 |
Ok so upon further inspection. The motor stopped turning with a battery hooked up. Missing a brush on one side. Time to go brushless!
Did I smoke the esc and BEC? | Moparguy | Electronics | 11 | 04-28-2013 01:48 AM |
ESC up in smoke!!! | USMCRay1 | Losi Mini-Rock Crawler | 6 | 01-17-2012 11:59 AM |
did i just smoke my receiver or esc? | mudn_1 | Electronics | 1 | 02-15-2011 12:29 AM |
My esc up in smoke.. | stoneface | Electronics | 4 | 10-10-2010 10:08 PM |
Smoke/Overheating from ESC | SinCity | Axial SCX-10 | 6 | 06-14-2010 08:09 AM |
