09-10-2015, 08:46 AM | #21 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: YR Knuckles rub And I'm pretty certain you don't know your arse from your elbow. I'm also pretty sure Axial DO NOT print their name on a part so when its installed correctly their name is upside down, hence when you look at the pics in both post #1 & #6 & the Axial is the right way up its a dead giveaway the C-hub is on correctly. And I said it 5 posts before you lol |
09-10-2015, 09:17 AM | #22 |
Newbie Join Date: Aug 2015 Location: santa rosa
| Re: YR Knuckles rub
The bearings are seated all the way. I triple checked. The way the machining is done on the knuckles has them fit it at that angle. I am at work and can't post pics.
09-10-2015, 10:03 AM | #23 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: YR Knuckles rub
I found the problem. They're Yeah Racing parts. |
09-10-2015, 12:08 PM | #24 |
| Re: YR Knuckles rub
Exactly! Quality knuckles will fix the problem.
09-10-2015, 01:09 PM | #25 |
| Re: YR Knuckles rub
So Im new to crawling and have no idea if yeah racing is any good or not, Im taking it that they are not ? I will verify when I get home about the bearings being fully seated. I looked up axials alum knuckles and they seem a little over priced ? Get what you pay for maybe?
09-10-2015, 01:19 PM | #26 |
| Re: YR Knuckles rub
Yeah racing is in the same china boat as Integy. Hot Racing seems to be a bit better, some parts are quality, some are not. Front axles and knuckles/Cs are you get what you pay for. Axial universals and Vanquish parts have been going strong for 2 years on my wraith. |
09-10-2015, 01:27 PM | #27 |
| Re: YR Knuckles rub
Its possible that the knuckles only work correctly with the Yeah Racing c hubs. You could spend $15 on the c hubs to find out or put that money towards a pair of good knuckles like Vanquish, SSD, or STRC. Of course, there is the very real possibility they are just incredibly shitty knuckles that will never work right. |
09-10-2015, 02:36 PM | #28 |
| Re: YR Knuckles rub That maybe, but Yeah Racing is shit for quality, replace that crap with Axial or Vanquish parts and they will be stronger and last longer too. Cheap crap aluminum parts are made from cheap crappy grade aluminum and poorly machined to kinda the proper specs. EDIT: I can't believe fawking RC Driver did a review of YeahRacing aluminum junk for Wraith and said how great thier crap was...lol. Sad, truly sad. |
09-10-2015, 07:56 PM | #29 |
| Re: YR Knuckles rub
Well I ordered a set of vanquish knuckles. I will compare the 2 when they arrive to check the geometry.
09-10-2015, 09:03 PM | #30 | |
| Re: YR Knuckles rub Quote:
09-10-2015, 09:55 PM | #31 | ||
09-11-2015, 02:07 AM | #32 | |
I've ran axial, strc, HR and VP knuckles and C hubs mixed together and never had this issue. | |
09-11-2015, 07:32 AM | #33 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Re: YR Knuckles rub
I've had Axial STRC and VP. Out of the three I have owned VP had the best fit and finish.
09-11-2015, 08:38 AM | #34 |
| Re: YR Knuckles rub
Can anyone here post a pic of theirs so I can see what angles yours have?
09-11-2015, 09:33 AM | #35 |
| Re: YR Knuckles rub |
09-11-2015, 11:09 AM | #36 |
| Re: YR Knuckles rub
Thanks. Are those vanquish?
09-11-2015, 11:20 AM | #37 |
| Re: YR Knuckles rub
Yes, Vanquish Scale inner and outer.
09-14-2015, 07:20 PM | #38 |
| Re: YR Knuckles rub
Well I got my VP knuckles in and I can't get the larger size bearing to get in all the way.? I have the black ones with 0*
09-14-2015, 10:12 PM | #39 |
Newbie Join Date: Sep 2015 Location: US
| Re: YR Knuckles rub
Got them in. Dropped right in after they cooled off Sent from my DROID RAZR using Tapatalk |
YR Knuckles rub - Similar Threads | ||||
Rub trouble :) | visceral | Axial SCX-10 | 6 | 07-02-2015 09:54 AM |
Tire Rub. Help | juttsvw | RC4WD Trail Finder 2 | 22 | 05-03-2013 04:39 PM |
Possible rub Issue? | BrianP | Losi Mini-Rock Crawler | 0 | 11-05-2011 12:10 PM |
tire rub | ax10newguy | General Crawlers | 10 | 05-08-2010 12:32 AM |
rub | wanttocrawl | Newbie General | 4 | 08-13-2008 04:21 AM |
