02-13-2012, 11:35 PM | #201 |
Newbie Join Date: Jan 2012 Location: Awesome Malaysia
| FXR need to take the red wire out ?
Harley, Im using the dual FXR on the XR10 .. Also running the castle 10a bec .. Do i need to take out the red wire from the esc to the receiver since im running the the external bec ? ... or it does't matter ? Thanks. -sam |
02-13-2012, 11:38 PM | #202 |
| Re: FXR need to take the red wire out ? If you are running the BEC into the RX then yes you need to remove that wire.
02-13-2012, 11:42 PM | #203 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: Harley's Complete XR10 Guide
Is that on both ESC's or just the one nearest or connected to the BEC
02-13-2012, 11:44 PM | #204 |
| Re: Harley's Complete XR10 Guide Both. The issue is the difference in voltage between the internal and external BEC's (since ESC's have a BEC built into them). The difference in voltage makes the system want to "even out" and causes backfeeding of some sort and can/will fry the internal BEC of the ESC.
02-13-2012, 11:59 PM | #205 |
Thanks for the explanation Josh |
02-14-2012, 12:04 AM | #206 | |
| Re: FXR need to take the red wire out ? Quote:
Thanks Man ! . I'd power up with the red wire not removed. Its all turn on but the on off switch on both esc just not functioning and somehow i figure out something is not right . Remove both red wire and was lucky for not be able to witness the white smoke on these 200 bucks esc ! | |
02-16-2012, 03:23 PM | #207 |
Newbie Join Date: Feb 2011 Location: Australia
whats the best setups on the dual Tekin fxr esc's? What do you recommend or is there a Youtube video for that too?
02-27-2012, 07:02 PM | #208 |
Rock Stacker Join Date: Oct 2011 Location: milan
Hi there i need some help i have a axial xr10 with a stock chassis i would like to up grade my shocks to traxxas big bore.Would the xxlong work or not i will be using mini t springs.Would you have a parts number on the shocks please e-mail at rcmannitro@yahoo.com.asap thanks tracy |
02-27-2012, 07:06 PM | #209 | |
02-29-2012, 09:33 AM | #210 |
Hi there i have a axial xr10 and iam looking for a new servo would one of these 2 work savox sc-1268sg hi torque digital servo.361 oz or 37955s hitec v2 dig high resolution ht titanium servo.I olny have $100.00 to spend.And wear can i get a punk dig iam not doing comps.thanks for the help. |
03-04-2012, 01:39 PM | #211 |
Newbie Join Date: Mar 2012 Location: amarillo
I am wanting to run a single esc with dig on a dx3r pro is this possible if so i need some advice and a complete wiring diagram. Also could you tell me a good esc that can hadle 3s lipo and which battery to use in the stock battery mount on an xr10. help is appreciated thank you.
03-04-2012, 02:02 PM | #212 | |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
| Re: Harley's Complete XR10 Guide Quote:
With a DX3r and a Single ESC, you need either a homemade dig switch, or a Punk Dig Switch Dig Wiring (Punk Dig Example): Search "Punk Dig Wiring Diagram" Wiring Diagram for Punk Dig and BEC Recommended ESC: SEE POST #1 Battery Mount Info: READ POST #7 Battery Size Stock Chassis Mount: Page 3 of the XR10 Manual 30mm x 25mm x 90mm Battery Recommendations Stock Chassis Mount: High C Rating - Pick a reputable vendor. MY Battery Recommendation: See Post #7 and run a smaller battery out of the chassis....and remove the stock mount. | |
03-04-2012, 02:21 PM | #213 |
ok thank you very much and sorry for postin here im just tryin to figure this site out
03-08-2012, 04:47 PM | #214 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Lots of great info here Thanks Harley for all of it. Hey Harley I'm looking for a link to your build thread but I can't find one. |
03-15-2012, 07:01 PM | #215 |
Just finishing up a XR it's my first MOA been running a shafty with dig in the pro class, I'm pretty excited. I just have to give Harley some props for a fine peice of work, one that was extreamly useful all the way through. Thanks for all your work, help and guidence. Last edited by Stormin2u; 03-15-2012 at 07:03 PM. |
03-21-2012, 07:19 PM | #216 |
Just got my Hotwire in the mail to set up the FRXs. wondering if anyone is prepared to share their setup or is it all top secret stuff and trial and error? there are no setup sheets on the website for crawlers so wanted to know how or what was the best setup to go for?
03-22-2012, 04:23 PM | #217 |
Newbie Join Date: Mar 2012 Location: Seattle
This has been a really helpful thread, thank you!
03-24-2012, 01:24 AM | #218 |
Pebble Pounder Join Date: Apr 2011 Location: australia
| Re: Harley's Complete XR10 Guide Any chance of someone posting up pics of their hotwire profiles for front and rear tekin fxr`s with tekin motors 35t,45t,55t ? Would be appreciated , want a good base line to start with . |
04-02-2012, 07:04 AM | #219 |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
Best XR10 guide yet. Very helpful.
04-02-2012, 09:57 PM | #220 |
Hotwire profiles must be the holy grail as no one wants to share any info on them it seems.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-xr10/293775-harleys-complete-xr10-guide.html | ||||
兩個電變,兩個魔打,兩個電池,一個接收(receiver) - 慢爬攀岩車技術討論板 - RC-遙控車RC-EVOLUTION遙控工房模型論壇 - Powered by Discuz! | This thread | Refback | 03-05-2013 04:16 AM | |
可否請各位大大分享一下現役的轉向伺服機 - 越野車、大腳車、攀岩車 | This thread | Refback | 02-14-2013 06:19 PM | |
www.rccrawler-france.com: Forum Dedié aux Crawler et Scales Radio-Commandé en France, Conseils, Astuces pour Créations Chassis Complet, News, Galeries Photos, Liens Utiles • Afficher le sujet - Améliorations indispensables au Xr10 | This thread | Refback | 10-07-2011 04:52 AM | |
Crawl ANZ • View topic - dual esc | This thread | Refback | 10-07-2011 01:53 AM |
