10-25-2011, 06:27 PM | #61 | |
However, I dont believe that the Rowdy battery mounts will work with them without trimming the gearbox slightly... | |
10-25-2011, 06:40 PM | #62 |
Newbie Join Date: Oct 2011 Location: Edmonton
Just putting my XR together,front axle is done,went with the recommended turn buckle length For the steering @ 11.5mm but once I hooked everything up,I'm far from centered,not sure if they can be shortened anymore. I'm starting the rear axle tonight. What's an average for build time on this?is the factory setup alright to start with?? 1st crawler,so sorry for the dumb a$$ questions. Last edited by Rimripper; 10-25-2011 at 06:43 PM. |
05-03-2012, 02:12 PM | #63 |
| Re: Jeremy's XR10
A bit of an update: I still need to rebuild the shocks and limit them some to drop this truck a bit as well as mount my electronics permanently and it will be ready to roll. |
05-03-2012, 02:43 PM | #64 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
| Re: Jeremy's XR10
Lookin good! How are the RC4wd cases holding up? I've had zero issues with my VP cases, I'm just curious about their performance after time.
05-03-2012, 02:49 PM | #65 |
| Re: Jeremy's XR10
Well, I've been letting a new guy in our club drive this truck lately and they seem to be holding up to his driving. He's a pretty darn good driver, but I've had no issues with the cases so far... BTW, I was wrong about the Rowdy mount not fitting the RC4WD gearboxes.....it fit just fine...I suppose it was just tweaked a little. Last edited by JeremyH; 05-03-2012 at 02:52 PM. |
05-03-2012, 02:52 PM | #66 |
| Re: Jeremy's XR10
Good to hear, thanks. It's nice to have affordable options. How's the SA chassis?
05-03-2012, 02:55 PM | #67 |
| Re: Jeremy's XR10
That is the SA4.0. I like it! Nice and compact....light.....the same geometry that I am used to on my berg. It should work out nicely for me. |
05-03-2012, 03:10 PM | #68 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
| Re: Jeremy's XR10
Jeremy, the rig is looking great so far. Great meeting you at ECC.
05-03-2012, 03:12 PM | #69 |
| Re: Jeremy's XR10 |
05-03-2012, 03:55 PM | #70 |
| Re: Jeremy's XR10
Don't you know that Bergs are coming back |
05-03-2012, 06:02 PM | #71 |
| Re: Jeremy's XR10 |
05-03-2012, 10:19 PM | #72 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| Re: Jeremy's XR10
Traitor |
05-04-2012, 06:40 AM | #73 |
| Re: Jeremy's XR10 |
05-04-2012, 09:29 PM | #74 |
| Re: Jeremy's XR10
Well shit--we can't be buds anymore Looks good.. So compared to a heavy case do you feel its more controllable when having to bump over stuff like sharp /\ type stuff? |
05-07-2012, 08:02 AM | #75 |
| Re: Jeremy's XR10
Do you mean the gearcase? That definitely slides better than the bergs, but I still feel like I have to baby this truck.....I used to wad up my berg to the point that the XR guys would cringe and it handled that like a champ. We'll see how this truck goes.
05-07-2012, 08:03 AM | #76 |
| Re: Jeremy's XR10
I took this truck out for a test run over the weekend. It did pretty well, but does need a bit of tuning. Here are some progression pics from a line that is fun: |
05-07-2012, 08:11 AM | #77 |
| Re: Jeremy's XR10
After talking with a buddy and letting him mess with this truck, he pointed out some binding with the shocks. So I went home and immediately swapped out to a similar shock setup as my berg......SCX shocks in the rear and Kyosho RT5 Velvet shocks up front. No more binding! (never mind the rats nest wiring, I'll get that cleaned up soon) I also swapped out the rear upper links for a bit more clearance: Ready to rock: |
05-07-2012, 08:33 AM | #78 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: Jeremy's XR10
One of your rod ends is twisted to 1:30. Thats all |
05-07-2012, 08:37 AM | #79 |
| Re: Jeremy's XR10 |
05-07-2012, 08:43 AM | #80 |
| Re: Jeremy's XR10
BTW, this truck as pictured above sits at 4lb 14oz.
