01-16-2012, 08:24 PM | #1 |
Newbie Join Date: Nov 2011 Location: Taiwan
| ESC, Motor Plate and Gear choices...
Hi everybody, my XR10 stock gears are blown (including the spare ones) and I am thinking of rebuilding the whole rig... I've ordered chaotic special chassis and ti links all around. Q1. Now debating on the ESC part. I'm using Axial 55T motors (the orange one) Was using some Novatech esc and it's giving me problems... Should I take CC Mamba Micro Pro or wait for CC Sidewinder Micro? Q2. Because of gear problems I'm looking at motor plates and gears... Motor Plate: VP motor plate or RC4WD kit or Axial HD motor plate? Gears: RC4WD (out of stock) or Axial machined? everybody seems to love the RC4WD gears, but I don't see many reviews on the Axial Machined... are they not as reliable? most of the debate is whether to choose an in stock option or wait for the out of stock ones... Thanks first for any reply!! Last edited by elec-fuyu; 01-16-2012 at 08:44 PM. |
01-17-2012, 05:24 AM | #2 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
| Re: ESC, Motor Plate and Gear choices...
Wait for the RC4WD gears to come back in stock, then get the gears and the case/plate conversion at the same time. Are you going to be running 2 ESC's or one?
01-17-2012, 06:59 AM | #3 |
| Re: ESC, Motor Plate and Gear choices... |
01-17-2012, 07:11 AM | #4 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
For your ESCs either solution will work. I ran dual Mamba Micro Pros and really like them. I now run dual Sidewinder Micros, and they get a tad warm, but for me the size/weight savings is worth it. IF you think that at some point that you will switch to a pair of 35T motors, I would recommend the Mamba Micro Pros....they are a safer choice as they handle a bit more amperage. Either way, make sure to install a Castle BEC as well. |
01-17-2012, 07:51 AM | #5 | |
| Re: ESC, Motor Plate and Gear choices... Quote:
and yes I do have a CC BEC running at 7.4v for my servo~ thanks guys! | |
ESC, Motor Plate and Gear choices... - Similar Threads | ||||
Motor mount plate, gear upgrade and bearings? | ik632 | Axial XR10 | 9 | 01-17-2012 04:43 PM |
Stock esc motor choices? | Matthewboerner | Axial Wraith | 5 | 10-10-2011 08:58 PM |
ESC & motor choices | CMaD | Electronics | 4 | 07-05-2011 09:48 PM |
TTC ESC & 550 Motor choices ? | badgravity | Electronics | 1 | 04-19-2011 03:07 PM |
LCC motor and esc choices... | redswr | Team Losi Comp Crawler | 28 | 02-25-2011 09:22 AM |
