01-21-2012, 12:20 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Kingsport
| XR10 Tire and spring rub?
I just finished my build of my XR10 with the BJV4 chassis and titanium links and notice when on flat ground when turning the tires rub the shocks very bad. Any suggestions to eliminate this other than dialing out the steering with the transmitter? Im running: Stock shocks HB Rover (white) Tires Stock XR rims Hitec 7955TG Servo |
01-21-2012, 12:46 PM | #2 |
Rock Crawler Join Date: Oct 2007 Location: south of France
| Re: XR10 Tire and spring rub?
new wheels or narrowed the stock ones |
01-21-2012, 12:49 PM | #3 |
| Re: XR10 Tire and spring rub? |
01-21-2012, 12:53 PM | #4 |
01-21-2012, 01:16 PM | #5 |
I think i would rather purchase a set of Vanquish wheels and hubs. What size wheel and what size hub should i use? |
01-21-2012, 03:56 PM | #6 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Increase the caster. If you looking at the left side of the truck the the kunckle should be like this /. The lower pivot on the left side knuckle should be forward of the uppper pivot. I have mine maxed out in the last hole.
01-21-2012, 07:36 PM | #7 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
For $2.00 you can use the Traxxas hexes. They are 8mm and the stocks xr10s are 5.5mm - so you can pick up 2.5mmmm. P/N 3654 I think.
01-21-2012, 10:29 PM | #8 |
01-21-2012, 10:55 PM | #9 |
What do you guys think about running AX10 wheels on the XR? I just took my stock AX10 wheels and tires and mounted them on the XR and the steering works great at 100%. It did make the truck wider though.
01-22-2012, 01:41 AM | #10 |
I tried that, but it seemed too wide. I do comps though.
01-22-2012, 07:14 AM | #11 |
The AX10 wheels are fine if you don't mind the width of the wheel or the truck. If you get Vanquish wheels, a pretty common setup for the XR is 1" wide SLW wheels on .475 hubs front and .600 rear. If you use DH Vanquesh wheels in the front, .350 hubs work pretty well. |
01-22-2012, 07:30 AM | #12 |
01-22-2012, 09:06 AM | #13 |
Rock Stacker Join Date: Sep 2010 Location: Grass Valley
i also put on my ax10 offset wheels. helped alot. gonna order some new wheels though. just to wide to run in comps..
01-22-2012, 10:42 AM | #14 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
01-22-2012, 11:02 AM | #15 | |
| Re: XR10 Tire and spring rub? Quote: | |
01-22-2012, 11:40 AM | #16 |
You can narrow your stock wheels-I did this first. Latter I got 1" wide Vanquish wheels. Here is how to narrow your wheels. Narrowing stock XR-10 wheels Habor Freight sells a plastic welder.(its just a soldering iron with a wide tip) |
01-22-2012, 12:06 PM | #17 |
| Re: XR10 Tire and spring rub? Been running these on my MRC for a couple of years now without a problem, and i've had the XR10 just under a year, again no problems.
01-22-2012, 12:18 PM | #18 |
| Re: XR10 Tire and spring rub? No harder than AX offset wheels. All are straining your bearings and killing steering power. You buy an axle designed to minimize scrub radius, then kill it with wide offset wheels. If you can't afford new wheels narrowing the stock ones is the best option.
01-22-2012, 01:04 PM | #19 |
Newbie Join Date: Dec 2011 Location: va beach
I just narrowed the stock fronts and put them back together with JB Weld. They work great and i have no rubbing issues.
01-22-2012, 03:47 PM | #20 |
so if i do the 1" vanquish SLW wheels with the .475 hubs it would clear? also do i need the .600 hubs for the rear?
XR10 Tire and spring rub? - Similar Threads | ||||
tire rub | ax10newguy | General Crawlers | 10 | 05-08-2010 12:32 AM |
Stop tire rub on upper links with stock chassis | droopmodmrc | Losi Micro-Rock Crawler | 1 | 03-27-2010 01:25 PM |
tire rub...wheel offsets? | 73fordhighboy | Duratrax Cliff Climber | 10 | 10-20-2009 01:27 AM |
slingshot, revo shocks, tire rub problems?? | robchas | Axial AX-10 Scorpion | 15 | 05-15-2009 02:46 AM |
Axial tire rub | alpinehyperite | Newbie General | 6 | 06-10-2008 08:02 PM |
