10-08-2012, 10:03 AM | #401 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
| Re: Del Monte's Secret Agent build |
10-09-2012, 04:34 PM | #402 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
10-09-2012, 05:21 PM | #403 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
Oh man, that's bootleggin' right there. Revenuer gone be after you.
11-09-2012, 10:36 PM | #404 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| 2013 updates
Here's the first round of changes for my Agent for 2013. I saw a few guys on here playing with some really lightweight aluminum links, so I thought I would give it another try. These links are 3/16" solid 7075 externally threaded with a 5mm die. These are 5g a link, compared to 10-11g for my Ti lowers. 10 grams of weight savings doesn't sound like much, but it made a surprisingly big difference in the weight bias and handling of the truck. I played with a set of .035 walled AL tube lowers that weighted only 3g each, but they didn't survive the post-comp abuse last weekend. With the lighter weight rear links, I can now get away with running only 30g of knuckle weight per side, and finally use my Nordic Crawler weight holders from Tomy. I'm also trying out a set of DE racing wheels with VP 600 hubs. I can squeeze two weight plates per side in these wheels, and they are a lot more solid feeling than my HPI's. With a lathe'd down 600 hub, the wheels are within a 1g of my HPI wheels. Overall, these changes made a definite improvement. The weight bias is better even though the truck is lighter. I'm hoping that with the next round of changes I will be able to drop at least half of the knuckle weights, and get pretty close to the 3lb mark |
11-09-2012, 11:31 PM | #405 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Those alum links turned out nice, and quite a bit lighter. I was just looking around at work last night for alum scraps for links and rear axle shafts. 5mm threads...what rodends do you have on them? Wheels came out nice too. Damn, 3lbs. What is it running at currently? |
11-09-2012, 11:41 PM | #406 |
Ahh those diet crazes. Soon the lipo will be the heaviest thing on there. Looks good Jake. |
11-10-2012, 12:01 AM | #407 | |
Pebble Pounder Join Date: Nov 2010 Location: Australia
| Re: 2013 updates Quote:
That's a good result with the wheels, 1g heavier but with the beef of the vp hub and less flex in the wheel. Any plans for some y-town wheels? I heard there was something in the mix. Serious effort getting it that light and having good bias, keep it coming | |
11-10-2012, 12:20 AM | #408 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Nice stance Jake !!! The CG looks very low... These bent links are going on the front, aren't they ? Why that change ? Also a lil question : when preparing your shocks, do you full the shocks body to the brim ? I changed my big bores for some SCX 10 ones and despite the fact that they seem well mounted and full, the chassis is already creating some dampening... Is it normal ?
11-10-2012, 03:52 AM | #409 |
Rock Crawler Join Date: Jan 2011 Location: At home
Truck looks very good. The wheels look cool, I have a set of those Borrego wheels lying around for a while but haven't come around to mounting any tires to it. Do you think you can get 3 weights on with a 725 hub ?
11-10-2012, 08:28 AM | #410 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Pics don't work :(.... Can't wait to see them though....
11-10-2012, 09:02 AM | #411 | |
Those DE wheels are nice, the face is a bit flatter then the Losi's so the screws dont distort it to much too. Black looks tough Have you changed (or felt the need to) your foams up much or tried anything different getting down to the 3* mark? | |
11-10-2012, 11:32 AM | #412 | |
Quarry Creeper Join Date: Nov 2010 Location: livermore california
| Re: 2013 updates
Hey jake, Did the 5mm threads end up being shallow on the 3/16 alum, I mic'd some 3/16" and it's only 4.77 mm. I thought the o.d. Would need to be larger for full threads. Links look great though. Aaron Quote:
11-10-2012, 11:38 AM | #413 | |
| Re: Del Monte's Secret Agent build Quote:
3 will be tight with a 725 hub, but you can probably get them to fit if you remove a little material from the ribs inside the wheel. | |
11-10-2012, 11:40 AM | #414 |
| Re: 2013 updates They are a little shallow, but they seem fine so far. I could always CA the rod end on, or drill them for cross pins if needed.
11-10-2012, 12:16 PM | #415 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
11-10-2012, 12:25 PM | #416 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
What IS your current foam setup Jake? Rig looks killer as always. | |
11-10-2012, 03:07 PM | #417 |
11-10-2012, 04:01 PM | #418 |
| Re: Del Monte's Secret Agent build I'm running Narrow/5.25" Nova foams in the rear tires. In the fronts I am trying something different. I am running a rover foam wrapped in a Medium 5.0/5.25 Nova outer tuning ring. I can get a little more tire wrap with these, and they still have enough support for side hills. |
11-11-2012, 12:12 AM | #419 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Looks solid Jake I think about the same for links. Other ide was 1/4 al tubing with inserts. Since i run tubes al upper with cfk inserts on my super i think they will holding up great in a 2.2 rig. Whats your wheel tire combo weight?? Just get my new cfk wheels 14g a wheel plus a slw hub |
11-11-2012, 02:34 AM | #420 |
I weighted the unmodified DE rims and they were 52 grams total for four rims, so 13 grams a piece without hubs |
Del Monte's Secret Agent build - Similar Threads | ||||
Del Monte's XR10 Build #1 | Del Monte | Axial XR10 | 619 | 12-16-2014 09:10 AM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
