07-10-2012, 10:08 PM | #301 |
| Re: Del Monte's Secret Agent build
I really like the design of those weight bodies The ability to easily shift the bias point is pretty cool.
07-10-2012, 10:17 PM | #302 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: Del Monte's Secret Agent build Quote:
07-10-2012, 10:47 PM | #303 |
RCC Addict Join Date: Oct 2008 Location: Finland
Jake, I noticed you had to mount your weight behing the weight holder. Using a standard weight for this puts the weight holder off center as there is not enough room for the weight to be mounted behind the holder. The actual weight designed for this looks like this: You'll notice it has a channel cut out along the inside of the weight. This provides room for the knuckle and still allows the weight to be rotated. I'll have a set of these in the mail for you today. Tomi Last edited by Tomy; 07-10-2012 at 10:50 PM. |
07-10-2012, 10:53 PM | #304 | |
I don't think I will need the extra rings though. I will be switching to some Y-Town CF wheels here very soon | |
07-10-2012, 11:27 PM | #305 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
I always enjoy the tech updates in this thread. 3.5 lbs with a nice forward bias is a great target, the rig should go just about anywhere! I love mine at a hair under 4 lbs. (And slowly dropping)
07-11-2012, 05:31 PM | #306 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Do you remember the average running weight of yer LCC? HAD to be around 8lbs right? Do you foresee a level where going any lighter just wont work? With your growing experience in tuning the skinny rigs...do you think that ANY weight will work as long as you have the bias & tuning where it needs to be? Obviously I understand that at some point the sacrafice of durability wont make sense but in your opinion, is there a ceiling...or a floor in this case? J.D. |
07-11-2012, 07:59 PM | #307 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
I'm no expert on the crawling scene but lighter weight certainly has some good if not great advantages. Wayyy less strain on drivetrain parts, more throttle response and efficiency from electronics to name a few. Plus it's less strain on the older folk!! (My own personal experience!!) And i can't wait to start my SA!! |
07-11-2012, 08:56 PM | #308 |
| Re: Del Monte's Secret Agent build |
07-11-2012, 09:26 PM | #309 |
07-11-2012, 09:30 PM | #310 | |
07-11-2012, 09:43 PM | #311 | |
At some point there will definitely be a limit to how light a truck can be and still work. I kinda think we're limited by the components that can't be eliminated, motors, esc's, servo etc. If there is still is a set amount of weight that has to be in the truck, there will have to be a certain amount of weight everywhere else to make it all work. Having said that, I think a well tuned truck at 3.5lbs or less can still be very good at most comp sites. | |
07-11-2012, 09:55 PM | #312 | |
07-11-2012, 09:58 PM | #313 | |
07-11-2012, 10:00 PM | #314 | |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
X2. | |
07-11-2012, 11:02 PM | #315 | |
I don't think I ever weighed my LCC & thought somebody said recently that his was around double of what it is now. Guess that's what I get for thinkin | |
07-12-2012, 06:33 AM | #316 |
07-15-2012, 09:33 AM | #317 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
07-15-2012, 10:12 AM | #318 | |
Rock Stacker Join Date: Mar 2012 Location: Carson City
What VP hubs are you running front and rear.... Curious on the width to get everything to clear with that much steering. Impressive!!! | |
07-15-2012, 11:35 AM | #319 |
| Re: Del Monte's Secret Agent build No VP hubs at the moment, but the plastic HPI wheels are roughly equivalent to running a 350 VP hub on a .7 SLW. I finally cracked an HPI wheel hex yesterday, but it was under some pretty impressive abuse. I know a lot of guys had failures pretty quickly, so I guess I'll consider myself lucky that I didn't have one during competition.
07-15-2012, 11:59 AM | #320 |
I finally made some fancy aluminum crossmembers to replace the stock delrin ones. I was really surprised how much stiffer the chassis felt after adding these, and as an added bonus, they're actually lighter. The crossmembers are made from 3/16" .049 walled tubing and have .015 thick walls in the center Last edited by Del Monte; 07-15-2012 at 12:01 PM. |
Del Monte's Secret Agent build - Similar Threads | ||||
Del Monte's XR10 Build #1 | Del Monte | Axial XR10 | 619 | 12-16-2014 09:10 AM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Featherweight Secret Agent 3.5 Bodiless Build | 4xFord | Axial XR10 | 241 | 06-20-2012 05:43 AM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
