08-01-2012, 07:59 PM | #1 |
Newbie Join Date: Jan 2012 Location: quebec
| steering throw problem |
08-01-2012, 11:02 PM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
| Re: steering throw problem
Have you checked your servo endpoint adjustments? Or what tx are you using?
08-02-2012, 05:18 AM | #3 |
im using a traxxas link 2.4 4 channel modded with a 3 position switch on 3rd channel
08-02-2012, 06:40 AM | #4 |
Rock Crawler Join Date: May 2012 Location: Australia
What length servo horn is that? Is the drag link bolt catching on the underside of the servo? Looks close in the video. |
08-02-2012, 07:04 AM | #5 |
no there is nothing touching anywhere everything moves free and my toe in toe out is perfect at zero...
08-02-2012, 01:48 PM | #6 |
Rock Stacker Join Date: Mar 2012 Location: U.K.
it looks and if you listen the noise the servo is making it seems likely to be that the drag link screw is touching the servo case because your servo horn is not long enough. i solved this problen by putting a rounded lower profile screw through the drag link/servo horn and a slightly longer horn. it could also be that you need to take your servo horn off and set the steering trim to zero or the middle of the dial and then put the horn back on so that the wheels are set straight with the servo in the middle of it's travel. try the screw/longer horn first then remove the horn and re align if there is still a problem. and clock your chubs back if you havnt already hope this helps |
08-02-2012, 07:14 PM | #7 |
Newbie Join Date: Nov 2011 Location: earth
Did you find out what was causing the problem
08-07-2012, 01:30 PM | #8 |
Pebble Pounder Join Date: Jan 2010 Location: buffalo area
best I can tell from the video is that your problem is with your left side wheels(oposite the servo) when you watch the right wheel(servo side) it looks at though it is traveling as far as it can in bothe directions. take a look at the drag link that connects the front wheels and makie sure it is not too long nor too short. it looked like the front toe was right in the video but would double checking.
08-07-2012, 10:16 PM | #9 |
Quarry Creeper Join Date: Jan 2011 Location: westminster
Thats just how the stock geometry is with the steering arm on the knuckle. If you can trace someones vp red steering arm and cut one out of some alum , world of difference ! |
steering throw problem - Similar Threads | ||||
steering throw | bahogtubig | Redcat Crawlers | 9 | 07-13-2011 02:38 AM |
DX3 steering throw problem. | Mudsy | Electronics | 10 | 06-18-2011 02:06 PM |
Steering throw????? | WKcrawler17 | HPI Wheely King | 13 | 06-30-2009 01:24 AM |
more steering throw | TSK | Electronics | 5 | 01-16-2009 08:11 PM |
Steering throw | hitman46mod | HPI Wheely King | 6 | 11-22-2007 01:21 PM |
