Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Del Monte's Double Agent
Old 10-02-2015, 11:17 AM   #221
Custom Carbon Fiber
Robbob's Avatar
Default Re: Del Monte's Double Agent
Originally Posted by Del Monte View Post
Updates are lagging behind a little bit. Who would have thought that running a business, working a full time job, and teaching a few days a week would be time consuming
...... Jeremy leave that page out of the play book LOL.
Robbob is offline   Reply With Quote
Old 10-02-2015, 03:16 PM   #222
Y-Town Crawlers
Del Monte's Avatar
It's all good... My rigs will just probably be last to get all the good stuff
Del Monte is offline   Reply With Quote
Old 10-02-2015, 05:12 PM   #223
Teaching? What are you teaching?
Curcal is offline   Reply With Quote
Old 10-02-2015, 05:53 PM   #224
5th D Owner/Driver
cboggs's Avatar
Driving lessons?
cboggs is offline   Reply With Quote
Old 10-07-2015, 08:49 PM   #225
Y-Town Crawlers
Del Monte's Avatar
Originally Posted by cboggs View Post
Driving lessons?
That's only once a month... twice if I make it to a U4 race
I'm teaching machining at a local makerspace called Vocademy. It's a pretty neat gig actually. I have access to their CNC mill and lathe and other toys in my free time.
Old 10-08-2015, 05:14 AM   #226
Custom Carbon Fiber
Robbob's Avatar
/my napoleon dynamite voice/ ...... Lucky
Old 12-14-2015, 08:15 PM   #227
Y-Town Crawlers
Del Monte's Avatar
I've been pretty busy with Y-Town skunkworks lately, but I got finally got the production Double Agent 2.0 wrapped up. Over .250" more belly clearance than the original, and significantly more rigid with the carbon bracing.
The truck has been killing all of my local test lines in testing. A stripped tie rod bolt and funky brush failure cost me a chance at the podium in the BYB/BLC shootout over the weekend, but I'm really happy with how it handled in the comp debut.
Old 12-14-2015, 09:08 PM   #228
That thing looked crazy stable this weekend. Great job Jake!
Old 12-15-2015, 12:53 PM   #229
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Oh she's rigid alright. Flexes as much as the rock it's on.
J
SkaldidDog is offline   Reply With Quote
Old 12-15-2015, 02:25 PM   #230
mrG
How does the bracing mount?I can't tell from the pic.
mrG is offline   Reply With Quote
Old 12-15-2015, 03:22 PM   #231
I like the horizontal CF plate, seems it would eliminate some chassis spacers too.
travis c. is offline   Reply With Quote
Old 12-16-2015, 10:16 AM   #232
Y-Town Crawlers
Del Monte's Avatar
The only spacers left are the two in the cab. They can be made lighter and smaller now too, since they aren't doing much work.
The braces are just sandwiched between the chassis rails and a semi-captured nut. I'll grab a better pic tonight
Old 12-17-2015, 05:33 AM   #233
Custom Carbon Fiber
Robbob's Avatar
cough pictures?
Did you tweak the geometery on version 2?
And would ya mind sharing some foam setup info? My biggest handicap right now is foams and remembering how soft was too soft for the featherlights.
Old 12-17-2015, 07:03 AM   #234
X2 on the pics. I used toothpicks on my eyelids and stayed up all night waiting for those pics and they never came!!!
Rig looks SWEEEEEEEET!!!!!!
blandon is offline   Reply With Quote
Old 12-17-2015, 09:06 AM   #235
Definitely hyped on the new chassis. Diggin the lines and the CF spacers plates
The Crawl Space is offline   Reply With Quote
Old 12-17-2015, 10:42 AM   #236
Y-Town Crawlers
Del Monte's Avatar
I didn't have a chance to grab a good picture last night, but here's one I had on my phone.
Ignore the crooked brace. It's a result of rebuilding a truck after hanging out with the BYB all night
You can see that the braces are just sandwiched to the chassis. The whole package is considerably stiffer. Since the shock braces are separate pieces, you can still adjust the shock arms.
Old 12-17-2015, 11:16 AM   #237
It'd be a lot cooler with a SMW sticker on it!
Old 12-17-2015, 12:06 PM   #238
Thanks for the close up of the braces. I was racking my brain trying to figure out how they mounted, very cool concept and must be super rigid!!
Old 12-17-2015, 03:12 PM   #239
Y-Town Crawlers
Del Monte's Avatar
No problem. There are a few chassis using a similar concept these days, but I think this is the first to run braces through the entire chassis. It's amazing how much stiffer it is now, even when using just 1/16" side plates. The shock arms are still 1/8", but they could probably be reduced too.
Old 12-17-2015, 03:42 PM   #240
Looks pretty unique...are you using notches in the braces to locate and lock them in before the screws/nuts are tighten down. Would think that would stiffen it up even more and prevent them from sliding up or down.
Later EddieO
EddieO is offline   Reply With Quote
Del Monte's Double Agent - Similar Threads
Del Monte's Secret Agent build Del Monte Axial XR10 527 10-28-2016 11:03 AM
Del Monte's Creationfab sporty Del Monte Axial AX-10 Scorpion 25 05-09-2013 10:23 PM
Del Monte's '07 Falcon Del Monte Tamiya TLT Crawlers 48 07-26-2012 07:19 PM
Del Monte's MRC Del Monte Losi Mini-Rock Crawler 18 04-23-2010 09:24 AM
Del Monte's Banana Tuber Del Monte Tamiya TLT Crawlers 11 07-27-2008 01:43 PM
