08-30-2013, 09:50 AM | #141 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Del Monte's Double Agent Quote:
J | |
08-30-2013, 10:07 AM | #142 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
| Re: Del Monte's Double Agent |
08-30-2013, 09:35 PM | #143 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
08-30-2013, 10:00 PM | #144 |
Tonight, I finally got the chance to get my new motors off the fridge and into a comp rig where they belong. After a quick test run around the garage, I went out to Horsemen's for some epic sunset crawling. My initial impression is that the new HH motors are incredibly smooth and powerful. This set has a little less top end then I am used to, but the low end resolution was so good that it was easy to tip-toe through stuff that I usually power over. I'm also really starting to like my narrowed set of Voodoo silver's. Between the narrower tires and major weight drop, the truck feels much more forgiving than it did before. |
08-30-2013, 10:11 PM | #145 |
Oh dang, I can't imagine how airy that rig must feel. How about knuckle weights; any? Going to cut pins at all?
09-02-2013, 07:26 AM | #146 |
After getting more detailed feedback on the motors, we can easily drop down to 30t without worrying about torque But first we will just try laydown brushes so stall torque isn't affected. Jake already has small comm arms too. Since these are smoother than crawlmasters, I have multiple tuning rotors being made for people that may want higher punch or brake. Like Nabil, he doesn't care about startup much! |
09-02-2013, 09:22 AM | #147 |
Newbie Join Date: Nov 2011 Location: apple valley
So what is the weight difference between the 400 and 500? on the HH site they are the same... and how is the SL version comming along?
09-02-2013, 09:30 AM | #148 |
So what are the things between the motor and the spoon?
09-02-2013, 09:35 AM | #149 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
09-02-2013, 09:40 AM | #150 |
09-02-2013, 09:44 AM | #151 |
RCC Addict Join Date: May 2012 Location: Folsom
Mmmmmmm churros.
09-02-2013, 11:48 AM | #152 | |
Site will be updated after nats most likely. 500s are going to production about 4.75 ounces in the SL version and 5.5 for the regular. 400s are between 4.25 and 4.4 ounces regular, we are still prototyping. I am redesigning the SL 400 to improve the specs. The last version built was 3.5 ounces and didn't have good torque density. A net loss of 18% weight but 35% torque is not the right direction to chase in such a small motor. FEMM analysis is being used to push torque back up. | |
09-02-2013, 12:43 PM | #153 | |
09-02-2013, 12:45 PM | #154 |
09-06-2013, 09:14 AM | #155 |
Whats your final weight now?
09-06-2013, 09:29 PM | #156 |
09-12-2013, 10:22 AM | #157 |
How much did you narrow your Voodoo's? Also what advantage did/do you find running the silver compound over the gold? Last edited by chevotafun; 09-12-2013 at 11:53 AM. |
09-12-2013, 10:40 AM | #158 |
Nice seeing you again Jake, and even nicer checking out that insane rear axle! |
09-12-2013, 08:24 PM | #159 | |
The truck worked pretty well in AZ. Unfortunately, it took me a few courses to figure out how to drive it. The 20pts I gave up in the first two courses really hurt when driving against a field as talented as this year's. Here's some video from Harley's coverage. Sadly, its of my first course and the truck looks pretty bad on the bonus climb. Once I started getting comfortable with the truck, it really started to work great. | |
09-12-2013, 08:42 PM | #160 |
RCC Addict Join Date: Jan 2009 Location: O.C
Fantastic engineering work on that rear axle Jake! I'm sure you will be killing it as usual with that setup this year. I might even see you at a comp or two at some point. |
Del Monte's Double Agent - Similar Threads | ||||
Del Monte's Secret Agent build | Del Monte | Axial XR10 | 527 | 10-28-2016 11:03 AM |
Del Monte's Creationfab sporty | Del Monte | Axial AX-10 Scorpion | 25 | 05-09-2013 10:23 PM |
Del Monte's '07 Falcon | Del Monte | Tamiya TLT Crawlers | 48 | 07-26-2012 07:19 PM |
Del Monte's MRC | Del Monte | Losi Mini-Rock Crawler | 18 | 04-23-2010 09:24 AM |
Del Monte's Banana Tuber | Del Monte | Tamiya TLT Crawlers | 11 | 07-27-2008 01:43 PM |
