08-28-2015, 06:09 AM | #1 |
Newbie Join Date: Dec 2009 Location: ANDOVER TOWNSHIP
| More power in reverse
Just plugged my Yeti in for the first time. Set the end points and it seems there is more power in reverse then forward?? Mamba X manual says Futaba radio needs to be in servo reverse but then the transmitter is backwards/reversed.
08-28-2015, 07:30 AM | #2 |
Rock Stacker Join Date: Aug 2015 Location: APO
Ha. This exact same thing happened to me too last night. Not sure on the X, but the MM2 I just switched any two of the esc wires (red and black) and then put the Futaba radio on receiver reverse and it works great. (Thing is insane fast even on 4s) |
08-28-2015, 08:43 AM | #3 |
| Re: More power in reverse
Careful now. I don't have a Futaba but i don't think you can go switching wires if he is running a sensored motor.
08-28-2015, 09:04 AM | #4 |
None sensored
08-28-2015, 09:11 AM | #5 |
Newbie Join Date: May 2015 Location: Greenville, SC
Futaba radio needs to be set to reverse throttle, then figure out if you need to switch one of the motor wires.
08-28-2015, 10:26 AM | #6 |
| Re: More power in reverse Thank you,1windsor1 This thing is rippin'
08-28-2015, 11:42 AM | #7 |
Nice. It's more awesome than I expected! Hope it is for you, too!
More power in reverse - Similar Threads | ||||
tekin rs only has 50% power in reverse | realsickclown | Electronics | 8 | 08-27-2013 03:28 PM |
Little power in reverse | nuckle | Electronics | 2 | 02-28-2013 08:28 AM |
Reverse power | klausdenmark | Newbie General | 2 | 06-22-2012 04:21 PM |
EVX (3014) has more power in reverse | Brawler | Electronics | 2 | 01-31-2011 08:05 PM |
Reverse Power Problem need help | bulletproofcustoms | Tamiya Clod Buster | 2 | 11-15-2005 05:13 AM |
