Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Tuned Yeti XL suspension
Old 11-09-2015, 05:53 AM   #1
Default Tuned Yeti XL suspension
I've been working on tuning my suspension over the past couple of weeks. I wasn't happy with the way the truck handled under speed and bumps right out of the box so I made the following adjustments. It mobs really well now and tracks amazingly through the bumps and jumps.
see youtube video description for details.
watch in 4K resolution on a computer for best detail.
Yeti XL suspension Setup:
Front:
-Axial Green Springs 5.35lb adjusted 3/4 up body
-40wt shock oil and 4-hole 1.4mm shock piston
-Solar D77 Servo @ 6.0V (368 oz/in via CC BEC)
-GPM servo link with plastic ends
-Dhawk bellcrank
-Aluminum camber and steering links with stock plastic ends
-GPM C-hub and Knuckles
-3 bearing mod, 3 shims at pinion, 1 shim at c-clip
-Toe in: Measured Front:6-1/2 Rear: 6-5/8 to outside of tire for 1/16" difference. (front being smaller for toe-in)
-Camber: stock measurements
Rear:
-stock links and axles
-Axial Red springs 3.34lb adjusted mid body
-20wt shock oil and 6-hole 1.4mm shock piston
-Hot Racing rear swaybar with notched (lighter) torsion rod
-3 bearing mod, 3 shims at pinion, 1 shim at c-clip.
Wheels Tires:
-Axial 8 Spoke oversized rims
-RC4WD Mickey Thompson MTZ tires with additional 1" thk foam inside and out to bulge sidewalls
-Hot Racing +5mm hubs
***Note that this hub and wheel combo require the red Hot Racing spacers behind the wheels to be flipped. If you don't run them you'll have to source a spacer or 3/4" washer.
BrandonM95 is offline   Reply With Quote
Old 11-14-2015, 09:54 AM   #2
EAB
Default Re: Tuned Yeti XL suspension
Ha! Good way to exercise the dogs.
EAB is offline   Reply With Quote
Old 11-14-2015, 10:14 AM   #3
With all that room and I see equipment
Tracks dozer ? You should have a track built
Kx450 is offline   Reply With Quote
Old 11-16-2015, 07:49 PM   #4
That's exactly what I do. Let other people build my basing spots for me I just have to find them.
pro mod steve is offline   Reply With Quote
Old 11-17-2015, 04:58 PM   #5
What wheels and tires are those and what foams are in them
They look good
Old 11-17-2015, 05:27 PM   #6
Haha, I just poach the local construction sites during the weekends, that's all. This is a drainage field at a new church that went up.
Saturdays fun
Mickey Thompson MTZs with their stock foams an additional 1" of craft store foam on each side to bulge sidewall and help protect the beadlock screws.
link to forum thread with pictures
Tuned Yeti XL suspension - Similar Threads
Yeti suspension thread? dusty husky Axial Yeti 17 11-08-2015 01:38 PM
straight Yeti Rear Upper Suspension Link | home made le varan Axial Yeti 15 08-19-2015 01:53 AM
Yeti with very little front suspension travel coreyfro Axial Yeti 7 06-26-2015 10:22 AM
Yeti XL Lower suspension and hop ups StubbyUSC Axial Yeti XL 1 05-28-2015 06:04 PM
Yeti spring rates and suspension tuning? npcaldwell Axial Yeti 6 04-09-2015 11:42 AM
