Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc
Old 07-24-2014, 12:03 AM   #21
Default Re: Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc
will the EXO front universal axles work (AX30415)?
dextan22 is offline   Reply With Quote
Old 07-24-2014, 08:07 AM   #22
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Yes, the ID of all the bearings in the new knuckle are the same. They should bolt in just like the EXO.
Harley is offline   Reply With Quote
Old 07-24-2014, 11:10 AM   #23
Could someone measure the fuel cell box from the yeti,I was wondering the dimensions of it.
jcanuck is offline   Reply With Quote
Old 07-24-2014, 11:19 AM   #24
Originally Posted by Del Monte View Post
Mine weighs just over 12 oz
Txs
Bowler is offline   Reply With Quote
Old 07-24-2014, 12:00 PM   #25
20K Club
Harley's Avatar
I'll try and get that done tonight.
Old 07-26-2014, 09:50 AM   #26
jpf
great tread Josh;) I vote this to be a sticky
jpf is offline   Reply With Quote
Old 07-29-2014, 04:11 AM   #27
Can we also add (either in this thread or a new one) a recommended upgrades list (or highlight the existing list). I know it'll be depends t on what you want to do, so let's say first recommended list is for durability or common bad parts out of the box.
Just a thought now that more people have a yeti.
Aebous is offline   Reply With Quote
Old 07-29-2014, 04:27 AM   #28
+1 on a dedicated upgrade list for the Yeti
SilicaStorm is offline   Reply With Quote
Old 07-29-2014, 07:41 AM   #29
20K Club
Harley's Avatar
I'll do a beginners guide like I did for the Wraith, but I want to give it a few more weeks at least until I have as good of a feel for the truck as I can.
Old 07-29-2014, 07:23 PM   #30
Would a Tekin ROC 412 3100kV motor be compatible with the Yeti's stock ESC? I'm guessing no because I assume the ESC doesn't have a sensor port. Did I answer my own question?
bilinvic is offline   Reply With Quote
Old 07-29-2014, 08:41 PM   #31
20K Club
Harley's Avatar
While it would work, you wouldn't get the benefit of the motor until switching to a sensored ESC. I am running the ROC 412 right now but I am planning on switching that out soon. Hopefully by this weekend I'll have a new system installed.
Old 07-29-2014, 08:42 PM   #32
Will you be switching to a pro 4 HD? What kV?
fatroofus is offline   Reply With Quote
Old 07-29-2014, 08:52 PM   #33
20K Club
Harley's Avatar
Pro4 HD 3000kv and a RX8.
Old 07-30-2014, 10:59 AM   #34
Could you measure the outside dimensions of the fuel cell? And would a MMP fit in it?
R/C Bashist is offline   Reply With Quote
Old 07-30-2014, 11:02 AM   #35
20K Club
Harley's Avatar
I've been meaning to get that done! I'll knock it out tonight.
Old 07-30-2014, 08:03 PM   #36
I was watching your video last night of locking the front diff and was wondering if you had tried the 100,000 wt diff oil and if so how did it work on it?
greencrawler is offline   Reply With Quote
Old 07-30-2014, 08:08 PM   #37
20K Club
Harley's Avatar
I ran with Jason and he filled his diff with a very heavy silicone, probably more like 500K. It worked pretty well, but for me, locked is the way I plan to stay.
Old 07-30-2014, 08:13 PM   #38
TSK
Shelf queen
TSK's Avatar
Can you get the rear upper link eye to eye please?
Gonna run that Dlux u4 truss and rear housing, but the truss typically needs a Jato to lengthen the link to fit on a wraith so I'm gonna need to make some tlinks o fit.
TSK is offline   Reply With Quote
Old 07-30-2014, 08:15 PM   #39
20K Club
Harley's Avatar
5.75" I'll add that to the list.
Adding the fuel cell dimensions now.
Old 07-30-2014, 08:15 PM   #40
20K Club
Harley's Avatar
Fuel Cell, also adding to the front page.
These are rough but good enough for just about anything you guys probably need at a high level of planning.
Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc - Similar Threads
Yeti Parts Blue Monkey RC Chassis and Suspension 56 07-02-2019 06:11 AM
Yeti parts shared photon_trap Axial Yeti 7 07-09-2014 08:58 PM
hilux/Mojave parts compatibility? Corey123 Paint and Body 3 03-01-2014 04:12 AM
parts compatibility bmxwayne Redcat Crawlers 2 03-27-2012 07:21 PM
scx10 - ax10 parts compatibility Longgun101 Axial SCX-10 5 11-25-2009 11:37 PM
