Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc
Old 07-16-2014, 12:12 PM   #1
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Default Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc
I'll attempt to aggregate all the info from the build threads, manual and personal experience here for easy reference for anyone buying/building their Yeti's.
Measurements
Front Links (eye to eye)
Steering Links: 77mm
Caster Links: 77mm
Rear Links (eye to eye)
Trailing arms: 140mm
Front to first shock position: 78.5mm
Front to second shock position: 102.5mm
Upper links: 145mm
Front Shocks:
Extended: 92mm
Compressed: 70mm
Shock travel = 22mm
Front springs = 54mm @ 4.33lbs/in (Yellow)
Preloaded spring length = 45mm
Preloaded spring compressions = 9mm = .37"
Preloaded spring force = 1.60 lbs
Compressed spring length = 23mm
Total Spring Compression = 31mm = 1.22"
Compressed spring force = 5.28 lbs
Rear Shocks:
Extended: 128mm
Compressed: 85mm
Wheelbase: 14.25"
Front Track width: 12.75"
Front Track width with Vanquish SLW 225 Hubs: 12.25"
Battery Compartment size:
49.3mm Wide x 150mm Long x 23.2-35.2mm Tall (adjustable)
Parts Compatibility
Exo Compatible Parts
Front Bulkhead – AX80091
Diff Case – AX80002
Diff Gear Set – AX30390
Input Shaft (Diff Pinion) – AX30408
Differential Gear (Ring and Pinion Gear) – AX30392
Steering Knuckle Kingpins – AX30382
Exo Heavy Duty Differential Input Shaft (dog bone cup on the T-case) – AX30383
Exo Heavy Duty Differential Output Shaft (dog bone cup for front axle) – AX30381
Exo Dogbone 7x96 (front axle shafts) – AX30418
Front Suspension Arms – AX80111
Front Steering Knuckle Carriers – AX80106
EXO RTR Links – AX80119
EXO Compatible Option Parts
Universal Front Axles - AX30415
Wraith Compatible Parts
AR60 OCP Axle Housing – AX80069
AR60 OCP Differential Cover (also includes link mounts and bearing caps) – AX80070
AR60 OCP 4-link Mount – AX80072
AR60 OCP Straight Axle Adapter – AX80071
AR60 Rear Axle Shafts – AX30776
Input Shaft (Diff Pinion shaft) – AX30408
Diff Case – AX80002
Heavy Duty Locker – AX30500
Y-380 Cage/Body Parts
Cage Top, Rear and Tire Carrier – AX31117
Cage Front and inserts – AX31116
Cage Sides – AX3115
Clear Body – AX31140
Clear Interior – AX31141
Driver Heads – AX31049
Exo Rear Light Bezel and Radiator set – AX80103
Required Hardware to complete body
AXA0437 x 2 = 20 screws (12 needed)
AXA436 x 1 = 10 screws (6 needed)
AXA0422 x 2 = 20 screws (16 needed)
AXA435 x 1 = 10 screws (2 needed)
AXA117 x 1 = 10 screws (3 needed)
Total Weight - ~12 ounces
Transmission Parts List
Spur Gear Cover - AX31107
Motor Mount - AX31106
Case - AX31108
Top Shaft - AX31127
Bottom Shaft - AX31129
Internal Gear set - AX31130
Transfer Case Gear set - AX31131
Transfer Case Output Shaft - AX31134
Spur Gear - AX31065
Slipper Pad - AX31068
Slipper Spring - AX30413
Slipper Plate (front) - AX31059
Slipper Plate (rear) - Ax31067
5x11x4 Bearings (x10)
4mm E-clips (x2) - AXA1391
2x10mm Gear Pin (x2) - AX30163
2x11mm Gear Pin (x1) - AX31028
M3x18mm Countersunk Screw (x4) - AXA148
M3x25mm Countersunk Screw (x2) - AXA150
M3x12mm Countersunk Screw (x1) - AXA146
M4x12mm Caphead Screw (x2) - AX31121
M4 Washer (x2) - AXA1071
M4 Locknut (x1) - AXA1045
Gear Ratios
Stock Pinion and Spur: 16/64 = 4:1
"Inside" Transmission: 26/28 = 1.08:1
Transfer Case" 15/15/27 = 1.8:1
Overall Gear Ratio with different pinion and spur ratios
Transmission Gearing Comparison of Yeti to Wraith
Yeti Transmission w/o pinion and spur: 1.94:1
Wraith Transmission w/o pinion and spur: 2.6:1
Yeti Transmission with 16/64 gearing: 7.75:1
Wraith Transmission with 20/80 gearing: 10.4:1
Yeti Transmission with 12/64 gearing: 10.3:1
Rear Sway Bar
Arm Length: 2.5"
Overall Width: 4.75"
Width between mounts: 3.5625"
Sway Bar Links: 2.25"
Fuel Cell
A larger version of this image can be found on Page 3 of this thread
Harley is offline   Reply With Quote
Old 07-16-2014, 12:32 PM   #2
Default Re: Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc
So far this is the best Yeti Thread ever.
Thanks!
Generis is offline   Reply With Quote
Old 07-16-2014, 01:54 PM   #3
Great news on the Diff casings and gears. It means we can use HR or other stronger diff casings and the HPI spider gears. In other words I already have a set of replacement spider gears and paper gaskets.
if0rg0t2remember is offline   Reply With Quote
Old 07-16-2014, 04:28 PM   #4
Does anyone have a twin hammers to measure those trailing arms? And blue monkey wraith ones? That would be phenomenal.
Josh, can you get us the rear sway bar lengths?
Death Trot is offline   Reply With Quote
Old 07-16-2014, 05:11 PM   #5
20K Club
Harley's Avatar
I think I can get all those dimensions for you. The Blue Monkey links are definitely shorter but I'm sure he'll have some for the Yeti soon based on his posts.
Old 07-16-2014, 06:26 PM   #6
Rear wb8 drive shaft length too!!!
Sorry, what rear SLW matches the front being the .225 you tested?
Old 07-16-2014, 06:32 PM   #7
Come and take them!ฎ
Hunter711's Avatar
Thank you Harley. Don't stop.
Hunter711 is offline   Reply With Quote
Old 07-16-2014, 07:30 PM   #8
Yup keep up the good work Harley, looking forward to seeing some more of your yeti...
axial 4x4 crawler is offline   Reply With Quote
Old 07-16-2014, 08:55 PM   #9
.475's
BC Racing is offline   Reply With Quote
Old 07-18-2014, 12:54 AM   #10
Awesome thread,,, thanks so much for posting !!!
SilicaStorm is offline   Reply With Quote
Old 07-18-2014, 03:12 AM   #11
Whats the weight of the cage/body?
Bowler is offline   Reply With Quote
Old 07-18-2014, 05:15 PM   #12
great thread. nice to know. this is the second time I've preordered anything. first time not so great. bought the rc. then they quit building it, and no parts to fix it, but it looks like axial did it right this go around. so I'm taking a chance and got one
silver falcon is offline   Reply With Quote
Old 07-19-2014, 06:33 AM   #13
I am just saying that this thread should be a sticky!!! Good job Harley!!
darkmanx is offline   Reply With Quote
Old 07-20-2014, 06:08 PM   #14
Cage Sides – AX3115
[/B]
Does this list include the little part from the parts bag that will mount up to the rear body posts on the scx10? What is that part called? Sorry if I missed this somewhere...
bvrc is offline   Reply With Quote
Old 07-21-2014, 03:20 AM   #15
It looks like that bodypost is on part #AX31115
Old 07-21-2014, 09:02 AM   #16
Im Brandon
Brandon's Avatar
That is correct.
Brandon is offline   Reply With Quote
Old 07-21-2014, 12:18 PM   #17
20K Club
Harley's Avatar
I'll get answers to a lot of those other questions posted up ASAP. Was a busy week with leaving for the G6.
Old 07-23-2014, 08:58 PM   #18
20K Club
Harley's Avatar
Rear Sway Bar Info
Arm Length: 2.5"
Old 07-23-2014, 09:02 PM   #19
20K Club
Harley's Avatar
Outside shoulder to outside shoulder
Uncompressed: 5.875"
Compressed: 5.625"
Old 07-23-2014, 09:19 PM   #20
Y-Town Crawlers
Del Monte's Avatar
Mine weighs just over 12 oz
Del Monte is offline   Reply With Quote
Axial Yeti - Critical Dimensions, Parts compatibility, Gearing etc - Similar Threads
Yeti Parts Blue Monkey RC Chassis and Suspension 56 07-02-2019 06:11 AM
Yeti parts shared photon_trap Axial Yeti 7 07-09-2014 08:58 PM
hilux/Mojave parts compatibility? Corey123 Paint and Body 3 03-01-2014 04:12 AM
parts compatibility bmxwayne Redcat Crawlers 2 03-27-2012 07:21 PM
scx10 - ax10 parts compatibility Longgun101 Axial SCX-10 5 11-25-2009 11:37 PM
