Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Mat's Yeti
Old 09-04-2014, 04:49 AM   #1
mat
Default Mat's Yeti
Finally my Bday present from all the family arrived yesterday!! (possibly the first in the UK?!) I know you've all seen them by now but hey, it's my new toy!! :P
Ooooo boxy!!
More boxyness!!
Ran a pack through last night after doing the standard pre-run checks and it was top fun!! I'm going to keep this on the side of racer rather than crawler and pretty much stock....(Probably not though!) I actually prefer the harder compound tires, getting some great 3 wheel drift action!
mat is offline   Reply With Quote
Old 09-04-2014, 08:16 AM   #2
Default Re: Mat's Yeti
I take it that you approve of your new vehicle?
A couple of questions...1. Would you run it box stock in a G6 event?
which leads to 2. What do you think about running in a big event where
all (say 500) racers have the same-looking car? confusing? in other words,
will you keep the stock body? congrats on your new Yeti
mr dave is offline   Reply With Quote
Old 09-04-2014, 01:05 PM   #3
mat
Yep, I approve lol! It's a fun and unique truck to drive
Unfortunately where I live there is no real scale scene never mind comps of any sort.
At the moment I'm revelling in its newness but I'm sure it won't be long until I put my own stamp on it
Old 09-06-2014, 05:44 PM   #4
mat
So it took nearly all of 24hrs for me to start putting my stamp on my Yeti...couldn't resist! Mostly concentrating on the looks than performance, I'm more than happy with the stock setup for what I do with it.
First up wheels....the fronts are stock RC4WD Racelines but the rears are using the rear hub from the Yeti, they fit together perfect with no modding. I noticed RC4WD have brought out a range of 5 and 6 lug hub adaptors in different offsets, I'm sure the 6 lug will fit. Might be an alternative to the Vanquish hubs.
Next up the body, I was so close to cutting up the stock body to see what I could do with it but just couldn't bring myself to do it...especially with my fiance giving me the "are you jeffing serious" look, for wanting to hack up my bday present!
So decided to make my own panels in the end. (much safer task!). I also lowered the cockpit a little on the back end. Just wasn't digging the raked look.
Here's a little vid of my Yeti on 2s. More than enough for my garden! Just love the way it drives
Mat's Axial Yeti - YouTube
Old 09-09-2014, 02:08 PM   #5
mat
I've been doing a bit of interior decorating........
Old 09-09-2014, 04:03 PM   #6
Come and take them!®
Hunter711's Avatar
Nitrous on a fuel fire? So Wrong!!!
Rig look's freakin great.
Hunter711 is offline   Reply With Quote
Old 09-10-2014, 04:31 AM   #7
mat
LOL! Thanks man
You never know when you might need emergency NOS!
Old 10-05-2014, 08:46 PM   #8
I like the spare tire mounted on the rear. Is that a part you can purchase or is this a mod?
jhawk19 is offline   Reply With Quote
Old 10-06-2014, 03:16 AM   #9
It comes in the spare parts bag with the rig.
Zombi is offline   Reply With Quote
Old 10-06-2014, 04:12 AM   #10
Really like the look of the rig. What did you make the panels out of?
blknslvr is offline   Reply With Quote
Old 10-06-2014, 04:17 AM   #11
Default Mat's Yeti
It's not my rig but I've made one similar - you use styrene sheets, 1mm or less thick. To shape them is easy, just heat them up with the mrs' hair dryer...
Old 10-29-2014, 04:13 AM   #12
mat
Been having a play with some ally sheet...... OOooooo shiny!
Plan is too dull it up a bit then stickers
Old 10-29-2014, 08:50 AM   #13
Do you have any pics of how you mounted the radiator ?
hotwheels000 is offline   Reply With Quote
Old 10-29-2014, 11:26 AM   #14
mat
Where the fan grills mount to the radiator, there's 2 little holes in the radiator to stop the grills spinning, I drilled the outer one on each side of the rad and tapped it to 2.5mm. I used some sticky back foam strip rapped around the frame then used some small "P" clips over the foam (the foam stops the P-clips sliding around)...and what do you know...the holes in the P-clips line up with the holes in the rad!! A bit of a fiddle but it seems solid.
Also made a little dirt guard....
.....and a de-bling!
Old 11-01-2014, 07:02 PM   #15
mat
Well got it all sticker-ed up, also had a few nice bit turn up...and a few more to come
Some steering help courtesy of Vanquish...
Having a little play with slo-mo today....
Mat's Axial Yeti 2 - YouTube
Old 12-24-2014, 09:18 PM   #16
Sorry for jumping on an old thread, but I finally was allowed to open one present of my choice on xmas eve, of course I went for the rc box shaped one, and my pops and I were trying to figure out how to run a hose from the gas cap to the fuel cell.. just wondering how you managed to mount yours! Love your ride man looks great! Happy holidays!
NoobCrawler4 is offline   Reply With Quote
Old 01-13-2015, 04:03 AM   #17
mat
Sorry for the late reply to this.
Use a longish screw through the gas cap and fuel cell then used some rc fuel hose and push it on to the screw, holds well Happy Holidays to you too
Small update, thought I'd give these GPM beadlock front face replacements a try. They went together sweet and seem to hold the bead tight (yet to run them for a proper test). My Vanquish hubs wouldn't fit straight off, the bolt holes would need drilling out.
Old 01-13-2015, 04:06 AM   #18
I rather like the look of those mate, very nice.
Old 01-13-2015, 04:55 AM   #19
mat
Thanks fella A light, cheap fill in until I can afford the Methods
The stock rim weight is around 16g and these weigh in at 43g
Old 02-25-2015, 05:48 PM   #20
any updates, the truck looks great!
photocycler is offline   Reply With Quote
Mat's Yeti - Similar Threads
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti FastEddy Axial Yeti 13 04-21-2015 07:33 AM
water yeti.. calling all yeti owners going2fast Axial Yeti 11 11-02-2014 05:43 PM
Mat's Willy! mat G-Made Sawback 45 01-22-2014 10:43 AM
Mat's SC10 mat Non Crawler RC's 3 05-28-2009 06:14 PM
Mat's EDGE mat Axial AX-10 Scorpion 17 04-22-2008 04:49 PM
