Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Yeti spur gear
Old 09-17-2014, 04:22 PM   #1
Default Yeti spur gear
32 pitch, 64 tooth (stock right?) stripped mine out. Not a fan of steel, and stock replacements are out of stock everywhere I've looked? Is there another brand that will work?
Pretty sure it was the motor mount shifting or bending on a hard landing.
Part 2 to my question is that I'm going to be switching from 2s to 3s so I'd like to gear down a bit to keep temps happy and amp spikes lower. Any Gearing suggestions from people running 3s? Figured now would be a good time since I need a new spur and can't get ahold of the stocker
Thanks!
SoCal Crawlr is offline   Reply With Quote
Old 09-17-2014, 04:40 PM   #2
Default Re: Yeti spur gear
I know that the stock gearing was made to run on 3s.
dextan22 is offline   Reply With Quote
Old 09-17-2014, 04:44 PM   #3
Yeah, but I've thermaled twice now on 2s so just trying to play it safe. Either way should be fine
Old 09-17-2014, 04:49 PM   #4
I was able to fit a team associated 62 tooth on mine with team ae slipper pad and it seems to be running good temp. Warm to touch after running for 30-45 mins on 3s
klubr1986 is offline   Reply With Quote
Old 09-17-2014, 04:51 PM   #5
zero mods to make it fit? also what's the ambient temp where you run?
Old 09-17-2014, 05:14 PM   #6
It's a tight fit on the shaft but it works...the slipper pad is a bit different but holds well... I'm in Seattle Tacoma area so temps have been around 70-80 lately and havnt had any issues yet
Old 09-18-2014, 08:20 PM   #7
What do you guys think is the biggest spur that will fit? Wouldn't it crawl better with a larger spur? I already dropped down to 12t pinion. I know I should just buy a new esc and motor. Thanks.
foxsuperduty is offline   Reply With Quote
Yeti spur gear - Similar Threads
Yeti spur gear T.A.Grove Axial Yeti 28 02-23-2015 05:57 PM
Is there a metal upgrade gear for the 80T spur gear? maddogs1965 Axial Wraith 9 03-25-2014 11:31 AM
Which pinion gear works best with RC4WD Steel spur gear? e32lover HPI Wheely King 8 03-10-2013 06:09 PM
Which spur gear and pinion gear with 35t motor vegas1973 General Crawlers 1 08-19-2012 11:42 AM
Wobbling spur gear....Need alum. gear hub! sickfab HPI Wheely King 26 10-01-2007 02:09 AM
