Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Issue with unlocked rear
Old 10-11-2015, 08:22 AM   #1
Default Issue with unlocked rear
Hey guys,
A few weeks ago I decided to run an open rear diff. I originally used orings on the axle shafts and 100000k silicone oil. The orings were not enough to keep the fluid in and it made a mess of the inside of the axle. Someone else recommend silicone ear plugs, the putty kind. I thought this would be a good idea because it won't leak or dry out. At slow speeds everything works great. Once I get on the throttle hard it makes a terrible ratcheting sound, almost like an impact driver. It also goes half as fast as it used too. It also only seems to do it when the wheels are under load. It will not make the noise when it's on the work bench
Is it possible the silicone is causing it to lock up too much? Not enough? I'm at a loss.
maxPOWAAA is offline   Reply With Quote
Old 10-11-2015, 08:58 AM   #2
Default Re: Issue with unlocked rear
you better take it a part . sounds like the ring and pinion are striped out . the ring gear may have come loose from the diff cup . those little screws are hard to get tight .
nickyszoe is offline   Reply With Quote
Old 10-12-2015, 09:03 PM   #3
Yeah, my guess is the ring and pinion skipping or the internal diff gears skipping.
totallypro is offline   Reply With Quote
Old 10-13-2015, 06:03 AM   #4
Yeah not sure what it was. The ring and pinion showed a little wear but not much at all. Same with the spider gears looked fine but I packed a little more silicone in there and it runs very smooth again. Hurry up weekend
Old 10-13-2015, 08:21 AM   #5
did you check both front and rear ?
Old 10-15-2015, 08:00 AM   #6
Location: Taylors Falls just hanging with the MNRCRC crew.
I like this option, I hope it proves to be dependable for you. Keep us informed.
Stormin2u is offline   Reply With Quote
Old 10-15-2015, 09:25 AM   #7
kinda had the same thing happen, it was front ring and pinion. also had the same issue with the unlocked rear, ended up putting the locked diff back in
ullose272 is offline   Reply With Quote
Old 10-15-2015, 12:42 PM   #8
I put a little more silicone in the housing and put it'll together. Ran it hard twice and haven't had any problems
Issue with unlocked rear - Similar Threads
rs10 rear axle issue tpain123 Redcat Crawlers 5 05-16-2011 07:22 AM
rear motor issue artl666 Electronics 3 11-10-2010 09:55 PM
Is DX3R worth it just to get FWD with unlocked rear keithgemmill Newbie General 15 09-26-2010 07:05 AM
Rear power issue? lildjloop RC4WD Bully 5 01-22-2010 10:59 AM
rear belt issue b2bomber General Crawlers 0 08-31-2006 12:45 PM
