04-07-2014, 05:38 PM | #21 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: SCX10 Knuckle and Rear Axle Weights
These two products appear to do similar things, weigh close to the same, but are quite different in price. Knuckle Weights for SCX10 Aluminum High Steer Knuckles - $45- (2.4 oz per wheel) Tuner Kit for SCX10 High Steer Knuckle Weight Systems - $17- (1.99 oz. per wheel) Is the price difference simply due to the brass? Do they ultimately do the same thing minus the weight difference? No knock! I think these look awesome and I'll be purchasing a set as soon as I know which one's I really need. Thanks. |
04-07-2014, 06:07 PM | #22 |
RCC Addict Join Date: Apr 2011 Location: San Diego
Tuner kit is additional weight you can add to the knuckle weight system. You need the knuckle weight system first....then if you need more weight you can get the tuner kit to get additional weight. So 2.4+1.99=4.39oz max per wheel. |
04-07-2014, 07:48 PM | #23 | |
Sent from my SCH-I545 using Tapatalk | |
SCX10 Knuckle and Rear Axle Weights - Similar Threads | ||||
Axial XR10 Stock Knuckle / Axle Weights | Blue Monkey RC | Axles, Trannys, T-case | 251 | 05-17-2014 06:49 AM |
Losi Crawler Knuckle and Rear Axle Weights | Blue Monkey RC | Axles, Trannys, T-case | 8 | 02-15-2013 01:24 PM |
Non steering aluminum rear axle knuckle conversion? | 65BAJA | Tamiya TLT Crawlers | 16 | 01-07-2007 01:34 AM |
