05-10-2012, 06:37 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
| SCX10 Knuckle and Rear Axle Weights Knuckle and Rear Axle Weight Systems for Axial SCX10 BMRC weight mounting systems are CNC machined from brass and powdercoated satin black. They feature hardened stainless steel hardware and start at 2 oz for stock/aluminum knuckles and 2.4 oz for aluminum high steer knuckles. Rear weight systems fit just about anything. Add-on weights can really pile on the ounces and you don't have to worry about your driveline components wearing excessively and breaking with lots of rotating wheel weight. BMRC non-rotating weight systems fit stock Honcho/Dingo wheels but may not work with some aftermarket 1.9 wheels. Please feel free contact us before purchasing if you have a concern. weight system for high steer knuckles: standard knuckles: tuner kit: Link to SCX10 weights, links and more: SCX10 Upgrades |
05-11-2012, 07:55 AM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
| Re: SCX10 Knuckle and Rear Axle Weights
Great idea. Any idea of compatibility for Vanquish 8deg setups? |
05-11-2012, 02:19 PM | #3 |
| Re: SCX10 Knuckle and Rear Axle Weights |
05-29-2012, 12:34 PM | #4 |
Rock Stacker Join Date: May 2008 Location: Rohnert park
will these work with the vanquist zero ackerman knuckles?
05-29-2012, 12:43 PM | #5 |
06-04-2012, 01:46 PM | #6 |
RCC Addict Join Date: Apr 2011 Location: San Diego
do these just stay on the knuckle using that set screw at the 'bottom' of the weight to apply pressure against the knuckle?
06-06-2012, 06:42 PM | #7 |
| Re: SCX10 Knuckle and Rear Axle Weights yes but i would say the set screw is on the side of the weight. the weight fits snug with no set screw so it doesn't take much to secure it tightly. i wanted the weight systems to require no more than a thumb and pointer finger to tighten (with a screwdriver style allen wrench) |
07-17-2012, 07:43 AM | #8 |
Rock Crawler Join Date: May 2009 Location: Hillsboro, OR / Kapolei, Hi
Has anyone taken you up on the Vanquish knuckle option? I got a set that I can loan you for the "cause". BTW, can we still get the 3oz, prototype version of the knuckle weights? I found a wheel that fits them nicely: Thank you! |
07-19-2012, 06:46 AM | #9 |
i've sold all the old 3oz and larger weights however i still have no problem making the current style with a custom/larger outside diameter to fill out any wheel. as for making weights for different knuckles i'd be happy to accept your offer. i'll likely keep them for a week if thats ok... |
08-23-2012, 11:20 AM | #10 |
We are pleased to announce the arrival of our newest knuckle weight system for the VP High Steer Knuckles for SCX10/AX10. Special thanks to Brian AKA 808DA6 for sending me the knuckles and helping to test the new system We've got 4-5 sets in stock at the moment and I should have some pics in a week or so then i'll put them online. PM me if you need a set in the meantime. |
08-28-2012, 08:50 AM | #11 |
The brass weights for VP High Steer Knuckles for SCX10/AX10 apparently fit the VP High Steer knuckles for Berg Thanks again to 808DA6. |
12-04-2012, 11:07 AM | #12 |
RCC Addict Join Date: May 2011 Location: Utah County
how about 8* high steer from VP?
12-22-2012, 09:21 PM | #13 |
Quarry Creeper Join Date: Jan 2011 Location: Augusta
These are def. on the wish list. Will be picking up a pair for the front and rear scx10 very soon. They look awesome. Nice job. |
02-03-2013, 09:08 AM | #14 |
| Re: SCX10 Knuckle and Rear Axle Weights VP 8 Degree Knuckle Weights: |
02-12-2013, 07:45 PM | #15 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
Can I mount these on Axial high steer knuckles running VP 1.9 OMF wheels?
02-13-2013, 12:15 PM | #16 |
Rock Stacker Join Date: Aug 2012 Location: Roan Mountain
Those look nice. How much for the Standard scx10/ax10 model?
02-15-2013, 07:15 AM | #17 | |
| Re: SCX10 Knuckle and Rear Axle Weights Quote:
BMRC SCX10 weight systems:
BMRC SCX10 Ti steering linkage:
09-11-2013, 07:38 AM | #18 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
lookin at these for the vp 8 degree (which I don;t have yet). but in general they look like they sit far enough back on the knuckle to allow one of the disc brake hex's to be use to mount the wheels?
09-12-2013, 07:34 PM | #19 |
| Re: SCX10 Knuckle and Rear Axle Weights I'm not sure I understand the question. Knuckle weights aren't made to fit every combo. More weight = more spacing to stuff it all in.
01-06-2014, 03:29 AM | #20 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
I think he it's wanting to know if these will work work rc4wd brake rotor hex hubs.
SCX10 Knuckle and Rear Axle Weights - Similar Threads | ||||
Axial XR10 Stock Knuckle / Axle Weights | Blue Monkey RC | Axles, Trannys, T-case | 251 | 05-17-2014 06:49 AM |
Losi Crawler Knuckle and Rear Axle Weights | Blue Monkey RC | Axles, Trannys, T-case | 8 | 02-15-2013 01:24 PM |
Non steering aluminum rear axle knuckle conversion? | 65BAJA | Tamiya TLT Crawlers | 16 | 01-07-2007 01:34 AM |
