04-02-2014, 03:15 PM | #21 |
| Re: Car prob question. (Vid included)
I think it's the hamster belt... gotta lube it up ro make it easier for that little fuzz ball to power that thing. |
04-02-2014, 05:27 PM | #22 |
Moderator Join Date: Jan 2004 Location: chicago
check the motor mount, tranny mount, anything that will want to move/twist when the drivetrain/rear end is wanting to rotate under decelleration or reverse. neat car. sounds good. ;) |
04-02-2014, 06:09 PM | #23 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
Thanks guys. Hoopty I see you exactly understand the problem circumstances this happens at. I'll be checking all these points mentioned in this thread. Rained most of the day today. Supposed to rain all day tomorrow. That's funny Johnny. I'll check the hamster wheel belt when I find it lol. I'll be a lot happier soon as I find this noise gremlin and get the real diff and trans fluid changed. Also I reset my trip meter on the last top off. Filled up after 250 miles today and I'm avg 29.4mpg!! 1/4 in town and some playing around in there. Thanks for the input guys. It's well recieved. |
04-02-2014, 06:12 PM | #24 |
does it squeak when driving in the rain? i was gonna ask that... ;)
04-02-2014, 06:14 PM | #25 |
Nope. No changes in the rain.
04-02-2014, 06:16 PM | #26 |
seems like the other guys might be onto something... http://forum.miata.net/vb/showthread.php?t=427231 whatver it is, hopin ya fix it. i bet its a little irritating after awhile, especially on a fun car like that. |
04-02-2014, 06:20 PM | #27 |
As fast as the sound cycles I'm inclined to say its a driveline issue. Something wheel/brake related wouldn't cycle so fast but the driveline rotates roughly 4 times faster than the tires do.
04-02-2014, 06:29 PM | #28 |
Awesome. I did search a lot on miata forums. Missed that one. Joined mx5nutz too and posed the issue there as well. That guy has the exact same issue described. Cars so low I can't even reach the front ujoint with a spray can and penetrating lube aerosol laying down lol. I'll have it on ramps soon. Be even greater if it's got grease certs. I sprayed the rear ujoint with the spray can lube and no change after a short trip up town so far. The two tire drive shafts are booted and all 4 boots are intact still. |
04-02-2014, 06:31 PM | #29 |
Spraying it with lube won't change anything. Does the car have any odd fast pulsing vibrations under hard acceleration or at the moment between acceleration and deceleration when you are lifting your foot off the pedal? |
04-02-2014, 06:40 PM | #30 |
Quarry Creeper Join Date: Jan 2009 Location: FONTANA
i say throw-out bearing. and thats coming from a backyard mechanic know-it-all . |
04-02-2014, 06:45 PM | #31 |
It'll shut it up till I get new ujoints ordered Haha. And no there's no vibration, shudder, or clunking whatsoever I'd expect from it being excessively worn. I've had wallered out ones before, even busted one I knew was bad on a 4wd front while hauling wood. It usually is pretty obvious. I'm about 98% sure the roller bearings in one one of the ujoints is dry now.
04-02-2014, 06:47 PM | #32 |
I will find a way to get under there tomorrow and report back. I'll include photos too if there's anything worth seein ;)
04-02-2014, 08:07 PM | #33 | |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Re: Car prob question. (Vid included) Quote:
If the dealer wasn't doing all the service work on my 200 for less than I could do it for myself, that car would likely need the booster ramps too | |
04-03-2014, 11:30 AM | #34 | |
Quarry Creeper Join Date: May 2009 Location: India
The second squeak sounds when the wheel has turned 1/4th turn. | |
04-03-2014, 02:17 PM | #35 |
Got under there today. Front ujoint is dry I believe. Some black residue on it. Sprayed the heck out of both with penetrating lube. Since I had it up I went ahead and changed the rear diff fluid. Looked pretty new. Only lightly brown and clear. Cleaned the magnetic plug( nearly nothing on it) and the top plug. Replaced bottom-filled In the top till it came out- and screwed the top plug back in.
04-03-2014, 02:27 PM | #36 |
Still squeakin lol. Don't do this at home. Sometimes a guys gotta do what a guys gotta do. Cars light anyways. Rear tires on ramps, front left on a jack, and well- you can see front right- |
04-03-2014, 03:26 PM | #37 |
| Re: Car prob question. (Vid included) dude… go get some cheap jackstands. that car is definitely heavy enough to squish you if you are under it and that 2x or bottle jack happened to kicked out.
04-03-2014, 03:39 PM | #38 |
Yea I admit it wasn't my best move. The rear was on car ramps, in gear, and ebrake engaged. I felt confident enough to sneak under there for 3mins or so the jack on the far side is actually a hydraulic scissor jack and a jack stand. Has a pin slide through. I had to share this bit of backyard don't do! I do need a couple stands for this kinda stuff, But heck I need them like once a year.
04-03-2014, 03:47 PM | #39 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
It only takes one time to drop on ya , And that may be your last.
04-03-2014, 05:21 PM | #40 |
RCC Addict Join Date: Jun 2008 Location: In the woods
If u don't have jack stands.Use cendar blocks or wood blocks under tires. And also if it is u-joints it will clank or thud when you first let off of the clutch.And then when it gets a little pressure on them it will stop unless they are about to fall out completely. |
Car prob question. (Vid included) - Similar Threads | ||||
Car 61 ~~ The Rock Cop ~~~ with VID ! | crunky | 1.9 Scale Rigs | 180 | 10-20-2013 01:01 PM |
vid/doc for all car guys... | STANG KILLA SS | Chit Chat | 7 | 03-20-2013 04:59 PM |
chassis question (pics included) | brianw | General Scale Talk | 3 | 02-18-2010 03:29 PM |
Simple Drag car (now with vid) | JasonInAugusta | Non Crawler RC's | 72 | 04-16-2008 10:43 AM |
In Car Nylint Vid | onefstsnake | Videos! | 5 | 09-07-2005 01:50 PM |
