08-29-2011, 02:49 PM | #1601 | |
Newbie Join Date: Jun 2011 Location: texas
well im looking at a slightly used 4pk or a really good deal on a new 4pks. I just wanted to know if i will be disappointed if i go with the 4pk. Im buying it mainly for my moa crawler. Do the changes make it better for the moa crawler? | |
08-29-2011, 02:52 PM | #1602 |
| Not really. I was still using the 4PK until a month or two ago. Not really anything you will notice much. The new directional pad is very nice though.
08-29-2011, 02:59 PM | #1603 |
| Ok thanks that's what i needed to know. If all it is is a d pad upgrade it doesn't seem worth it only for another 100 dollars when i already have plenty of rx's from my 3pk. I know that the new rx's are more channels and smaller.
08-29-2011, 03:39 PM | #1604 |
Quarry Creeper Join Date: May 2007 Location: Grass Valley California
Not sure if this will help but I was able to score a new 4pks as a replacement for a new but troubled 4pk. THANKS FUTABA !! Anyway besides the ability to download updates via your computer the thumb switch under the wheel looks much easier to use, they have given it a longer rocker it looks like. The 4pk was a little awkward for me to use the buttons on for f/r/ dig. Harley I will let you know later if I will be thankful or frightful for your help on deciding between the 4pl or the 4pks.
08-29-2011, 03:45 PM | #1605 | |
08-29-2011, 11:45 PM | #1606 |
Quarry Creeper Join Date: Jul 2007 Location: Orting
my scaler has dig and 4wheel steering. i can only use one or the other when competing. is there away i can lock out one or the by simply hitting a button? i know i will naturally want to use one or the other without even thinking about it and dont want to get screwed at a comp.
08-30-2011, 07:12 AM | #1607 | |
You could always just setup multiple models though. Let me know and we can define the programming. Last edited by Harley; 08-30-2011 at 07:16 AM. | |
09-01-2011, 05:51 AM | #1608 |
Newbie Join Date: Aug 2011 Location: Jakarta
| Glitch issue
Hi Harley.. I'm new on this forum. So nice to meet you.. I'm a Futaba fans since first time I played RC. And currently I look forward for a 4PKS. I think it's a pretty impressive Tx. I have question that I heard an issue that FASST system glitched while some FASST system Txs was turned on (more than 10 Tx). Is it true?? It happened on last April in Drift Competition while many drifter using FASST Txs, icl. 3PK, 4PK and 4PKS.. Have this problem occured before?? One of them asked Futaba and they answered they will give a free software update. Have Futaba updated their latest production?? Now most of them have changed into MT4X or M11.. Thanks Andi |
09-12-2011, 02:24 PM | #1609 |
Newbie Join Date: Sep 2011 Location: Gyöngyös
Hello. Ask for help from you. I have a Futaba 4PK bad gas and brake lever. Where can I take potential meters? Or if you have spare parts catalog also thank you. Thank you. Samu |
09-12-2011, 02:29 PM | #1610 |
| Futaba doesn't sell spare parts for the radio because they don't want people opening the radio themselves. You will need to send it in to a service center.
09-14-2011, 01:40 PM | #1611 |
You can't download updates via the computer. Not really sure where you saw that. The buttons are also all the same I'm pretty sure. I thought I saw something about the on line updates , I will have to look a little deeper. As far a the buttons , you are right I was looking at the photos on line at futaba and I though I saw something that was just all in the angle of the photo. THE BUTTONS ARE THE SAME. |
09-14-2011, 02:15 PM | #1612 | |
09-14-2011, 04:28 PM | #1613 |
Rock Stacker Join Date: Aug 2010 Location: Houston
My crawler and 4pk have been in hibernation for the past seven months. Today, I pull it out of the box to play around a bit but my 4pk doesn't recognize any throttle on the bar graphs. Servo works fine. I did a model/data reset and set it up like your video again. But still, I pull the trigger and the bars don't move at all.
09-14-2011, 06:17 PM | #1614 | |
09-14-2011, 07:12 PM | #1615 |
[QUOTE=Harley;3279240]Beyond doing a model reset there is little that could cause that. Something had to cause hardware damage.[/QUOTE I re-calibrated the receiver and transmitter and it works again!! I guess being stored too long messed with the connection or something. Hardware damage is the first thing that came to mind but I didn't want to believe it, I only got 8 hours on my Futaba. |
09-15-2011, 01:16 PM | #1616 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
Hey, i've been searching and aside from reading every page I haven't found my question or answer. Can you use DT2 to control both your digs like a 3 position switch? I have my radio set up via Harley's guide, i'm just wondering if this is an option so that I can use just 1 switch instead of 2 seperate for dig. |
09-15-2011, 01:20 PM | #1617 | |
09-16-2011, 04:39 PM | #1618 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
so I'm trying to reset up my mini with my 4pk...... I dont know how but some how I shut the steering off and cant get it to turn back on when I go to the servo view it does not show anything at all when I turn the wheel... it ran fine last time I ran my mini with my 4pk...but I screwed something up and dont know what! |
09-16-2011, 04:43 PM | #1619 | |
09-16-2011, 05:06 PM | #1620 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136728-4pk-setups-tips-tricks-help.html | ||||
• Afficher le sujet - Quelqu'un connais bien la radio Futaba 4PK ? | This thread | Refback | 10-05-2011 06:51 AM | |
• Afficher le sujet - Mon nouveau joujou | This thread | Refback | 10-05-2011 06:04 AM |
