10-30-2009, 10:40 AM | #221 |
Quarry Creeper Join Date: Jun 2005 Location: Maryland
I am wondering if you guys are having to flip the motor wires around since one front one back to get them going same way. or just go + to + or - to - on each of the motors and it reverses it for you. Have to check if I went red to negative or kept it color correct on the rear motor. |
10-30-2009, 06:28 PM | #222 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
Hey Robin, did you get all the parts you needed? Ordered one Oct 27, wondered if it shipped yet?
10-30-2009, 06:38 PM | #223 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
hey PunkRC, Ordered a dig from ya on the 26th of Oct. I know it said out of stock until th 28th but I was wondering now that its the 30th are they being sent out? Just curious. |
10-30-2009, 10:56 PM | #224 | |
Quarry Creeper Join Date: Dec 2008 Location: B.C. Canada
http://www.rccrawler.com/forum/showt...=182143&page=5 | |
10-31-2009, 10:18 AM | #225 | |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
11-18-2009, 08:23 AM | #226 |
Newbie Join Date: Dec 2008 Location: Portugal
Hello Guys I'm really needing help, i've received my dig Last week but it's no equal to the one in the first shoot..... Mine have 3 connectors and im lost with the conections.... I don't really know if its the v2 or the v1, or whats going on... Its has a lot of glitching and im afraid that i would wire something wrong.... Could someone post somo photos of the connection wiring ?! Thanks in advance for any anwser !! Best regards Pedro |
11-18-2009, 10:34 AM | #227 |
Pebble Pounder Join Date: Jul 2007 Location: Roy
Explain glitching more..... If your motors are not equal speed, it sounds like a motor timing issue perhaps... Ver 2+, say Dig Switch 2+ on it. Neither version had "glitching" issues. You may check your transmitter rate to 11ms instead of 5.5ms. Pedro, give me a call if you want at 435x881x9831. Last edited by PunkRC; 11-18-2009 at 10:37 AM. |
11-19-2009, 02:45 AM | #228 | |
First thanks for the fast response, i've been searching on the weeb and found your Youtube Channel. In there i found everything i need to know, mine is the V2+. What was i doing wrong : There are 3 conectors in the Dig, i was conecting all of them, one in 3 channel, one in Throtle and the other in ESC.... big messsss Just need to connect the 3 channel one, if you dont want Drag Brake... If you dont mind i will leave here the link to the YouTube movie that explain all. http://www.youtube.com/user/PunkRCVi.../1/Y6c_mVgwK3k I would like to thansk to Punk RC for the amazing work on Rock Crawling. Best regards and thanks again !!! Pedro Leitão | |
11-19-2009, 04:25 AM | #229 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Pedro, are you sure you dont have the 2 male plugs reversed? Have you tried it without the dig hooked up to make sure its not something else in the system? |
11-19-2009, 05:09 AM | #230 |
All fixed now, like i said in the post before. Since i dont need the drag from the Dig Switch just need to connect the wire to the 3 channel in the receiver. Thanks Best Regards Pedro |
11-20-2009, 02:44 AM | #231 |
Newbie Join Date: Oct 2008 Location: Portugal
Mr. Punkrc thanks for this goooooood work for crawling... 5x5 Miura73 |
11-20-2009, 08:49 AM | #232 |
Newbie Join Date: Jan 2008 Location: Benton
I run clod with four wheel sterring on a three channel radio and was wondering how I could incorporate a dig switch into the system without going to four channel radio. If this possible please let me know.
11-20-2009, 02:32 PM | #233 | |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
try this | |
11-20-2009, 02:33 PM | #234 |
I just got my PunkDig2+ delivered & installed last night-- (Running a TQ3 radio) WOW-- this thing is great! Thanks Punk RC! |
11-28-2009, 01:07 PM | #235 | ||
RCC Addict Join Date: Feb 2008 Location: Nevada
WOW!!! i'm lovin this little dig untit, i admit at first i had a problem, and started to panic until i read these two threads below, (i have the DX3R and my EPA's were set very low) changed them both to 60 and works like a charm it's worth the money thanks Punk RC Quote:
thanks for these two guys for posting this up also | ||
12-08-2009, 05:37 AM | #236 |
Rock Crawler Join Date: Oct 2006 Location: Germany
I got mine and its working great in my bully. One question: Can I run it on a 7,2V BEC or only as recommended with 6,5V ? I would like to use it on 7,2, because of the power-advantage for my hitec servo, but I didnīt want to ruin my dig switch. Thanks, Pete |
12-08-2009, 11:24 AM | #237 |
| I'm not sure if the dig switch can handle the extra voltage or not (I'll let Robin answer that) but if it can't you could always run the BEC power direct to the steering servo at 7.2 and let the ESC's onboard BEC power the reciever and dig switch.
12-08-2009, 11:29 AM | #238 | |
Pete | |
12-08-2009, 11:37 AM | #239 | |
Look at the first diagram here: CC BEC Questions The steering servo gets it power directly from the CC BEC and it's signal from the RX, and the ESC's BEC supplies power to the RX, which would then supply power to the dig switch. It would be simpler to run the whole thing at 7.2 though if the switch can take it. | |
12-13-2009, 12:05 AM | #240 |
I am doing some research for an MOA rig, this seems to be the dig to get. How much of an issue is Clod-Stall with this dig/setup? The rig I have in mind is a MOA Losi. To start with I'll be using the Rooster Crawler currently installed in my Axial. Thanks. |
