11-19-2011, 01:32 AM | #1621 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
Hello. I have 2 Castle Microsidewinder and I would like to use them with my 4PL and my XR10 but I have some question, please could you help me????? Could I connect directly one ESC to the receptor (with the 3 wires) and the other to the 3th channel with only 2 wires (black and yellow, no positive wire) so that can I suppress the bec to the receptor? I would like to use my BEC for my servo!! And can I feed the receptor with 7.5v (the same BEC for the servo 7,5 V and for the receptor, my car run 3S)? Thank you |
11-19-2011, 06:59 AM | #1622 | |
Other thread..... Doble ESC diagram? | |
11-19-2011, 07:16 AM | #1623 | |
11-19-2011, 07:39 AM | #1624 | |
I ALWAYS run my external BEC direct to the servo, it rules out what the RX can/can't handle in terms of voltage/load. | |
11-19-2011, 07:48 AM | #1625 | |
I always run through my RX with single servo setups. The RX's have no issue with the voltage or amperage. | |
11-19-2011, 08:31 AM | #1626 |
11-20-2011, 03:00 PM | #1627 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
I just bought a second RX so I can use my 4PL with my scaler and it is loosing bind or signal every so often. The green light is going to red for a second. I can't seem to make it happen. it's quite random. Does this sound like a bad RX? I have re bound with no change. The RX is a R2104GF.
11-21-2011, 12:20 AM | #1628 |
Pebble Pounder Join Date: Mar 2007 Location: Northern Ontario
WOW, I read this entire thread today and I feel I can answer any 4PL question...and I don't even have a 4PL...yet. ;) I was looking at getting a multi-channel radio to control my XR10 and to use with planes this morning so I was leaning towards a stick radio like the Futaba 6J. However, in reading this thread I have been convinced to buy a 4PL, which I had never even considered before. Being able to purchase compatible rx units for under $35 (R2106GF) will allow me to use this radio with my Axial Wraith, Axial AX10 and a half-dozen other cars and trucks I have in my collection as well. Heck I can finally retire my old favorite 3PB and run my 1/12th scale glitch-free! Thanks Harley, JDawg and all the others who chimed-in with helpful knowledge. You all made (and continue to make) this thread invaluable. Sean |
11-21-2011, 06:37 AM | #1629 |
Thanks for reading Sean. Hope it all clicks when you get one. It's a great radio.
11-21-2011, 07:19 AM | #1630 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Throttle?
My trigger seems a little sinsitive for my liking, were do I adjust to have more pull on the trigger before it gets to full speed?
11-21-2011, 07:41 AM | #1631 | |
You can add expo to your throttle curves if you want. | |
11-21-2011, 08:04 AM | #1632 | |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
The 4PL would be a good choice for your crawler or any other vehicle that stays on the ground. It's very good bang for the buck. | |
11-21-2011, 08:10 AM | #1633 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Harley, a quick (and i hope easy) question. I have dig set up on dt-2.rear is down front is up. How would i reverse that? Could i just swap esc plugs at the rx or is it done a differant way? Thanks, robert
11-21-2011, 08:14 AM | #1634 |
| Go to the dial menu, on the far right of the DT2 line it will say NOR or REV. Just change that to the opposite of what it is.
11-21-2011, 08:17 AM | #1635 |
11-22-2011, 09:48 AM | #1636 | |
Actually, that does not apply to radios operating at 2.4Ghz. Perhaps I wasn't clear in my earlier statement so I will elaborate. The "air" system I was looking at was a 2.4Ghz radio. All 2.4Ghz radios can be used for surface or air models. According to the FCC you can even use it in rockets, hovercraft and robots. But thank you for your concern nonetheless. Technically speaking, the only radios that are legally restricted are 72Mhz for air and 75Mhz for surface. There are other bands available but they are combined and/or licensed. (27, 49, 50 and 53 Mhz) Just wanted to make sure you to knew that. For further information please refer to the AMA website at Academy of Model Aeronautics for the US frequency chart and at the MAAC website at Model Aeronautics Association of Canada for the Canadian frequency chart. Sean | |
11-22-2011, 12:44 PM | #1637 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
11-22-2011, 12:49 PM | #1638 |
11-22-2011, 12:55 PM | #1639 |
Was set as Normal. Seems the common ground might still be a good idea sometimes. Recently redid the ESC's to dual FXR's and did the commen ground from the onset. Worked out perfectly. Kind Regards Rudolf |
11-27-2011, 07:58 PM | #1640 |
| Throttle epo.?
Ok, I am trying to adjust my throttle expo., but when I do it only affects my esc running the front axle. I can't figure out how to set both the esc's the same. Any advice would be great.
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
