02-07-2012, 07:06 AM | #1821 | |
Rock Crawler Join Date: Aug 2005 Location: Illinois
| Re: Futaba 4PL Setup, Tips, Tricks & Help Quote:
Thanks J | |
02-07-2012, 03:43 PM | #1822 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
| Re: Futaba 4PL Setup, Tips, Tricks & Help |
02-08-2012, 04:49 PM | #1823 |
Quarry Creeper Join Date: Jun 2009 Location: HOBBY HQ
can you set the 4pl 3rd channel to be a 3 position? like on the 3pmx?
02-08-2012, 04:55 PM | #1824 |
Rock Stacker Join Date: Mar 2011 Location: oconee
i have a 4pl and purchased a wraith rtr and was curious if there was a way to program to program the radio to turn the light off and on? any help would be awesome.
02-08-2012, 05:19 PM | #1825 |
02-08-2012, 05:22 PM | #1826 |
02-08-2012, 05:54 PM | #1827 |
02-10-2012, 08:13 AM | #1828 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
I just received my 4PL from RPP and I don't know if it is the updated version or not. Corey said that he just have gotten a new shipment in several weeks ago. So, I went ahead and purchased the RX & TX from him on 2/3/2012. Someone please tell me if I need to send it in to Futaba for an update. Here are the numbers: Last edited by ussprinceton2004; 02-10-2012 at 08:18 AM. |
02-10-2012, 08:25 AM | #1829 |
The first post has about every important post linked in it. Any info you need is likely there, including the update info. Only the first couple batches needed it and that was about a year ago. They are long gone.
02-11-2012, 09:50 AM | #1830 |
| Re: Futaba 4PL Setup, Tips, Tricks & Help I'm a little confused on how to translate the numbers on my TX I posted above, after looking at J's post. Can someone help me read the numbers so the manufacture date is clear to me? TIA.
02-11-2012, 09:55 AM | #1831 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
| Re: Futaba 4PL Setup, Tips, Tricks & Help If you're radio starts with B010 or B011 then you need an update. Your's is B103, a much higher number. You don't need an update.
02-13-2012, 02:29 PM | #1832 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
ok, need help. Just got a 4PL and I'm using my original Fxr Pro ESC for rear and new Fxr for front. Went through Harley's video and front ESC seemed to be doing everything right, BUT can't seem to get rear Fxr Pro to work or bind with TX and being red/green color blind, can't tell if it is binding... Now I've missed with it enough that front ESC not working. Tried binding with only one ESC plugged in at a time,is this the right way to do it? Also in Harley's wiring diagram it shows NO #3 port on the receiver and rear plugged into #4. Any ideas on where to start or what going on?
02-13-2012, 02:37 PM | #1833 |
OK, it appears channel 2 is the only one operating for ESC, so how do I get channel 3 or 4 to operat as throttle and read (bind) with the ESC?
02-13-2012, 02:43 PM | #1834 |
You went through the dual ESC video? Are the bar graphs showing up properly on the screen? You need to go to the model menu and switch it from S-FHSS to FHSS. The FXR Pro's don't read the higher speed signal for some reason. |
02-13-2012, 03:16 PM | #1835 |
Yes watched the video. OK Harley, the FHSS worked, But the rear is going in reverse (and shows that way on screen) and front is going forward... how do I reverse channel 4?
02-13-2012, 03:26 PM | #1836 |
02-13-2012, 03:33 PM | #1837 |
I guess that was a dumb question, but so confused and couldn't find it.... ALL works now, front ESC takes awhile to bind, but all works and thanks Harley!
02-13-2012, 03:35 PM | #1838 |
| Recalibrate your throttle and that bind time should go down. Or plug it into the Hotwire and bump up the deadband.
02-13-2012, 04:05 PM | #1839 |
Yeap that worked too.... Thanks again Harley, you are the man!
02-13-2012, 04:06 PM | #1840 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
