10-03-2011, 01:00 PM | #1541 | |
Are your capacitors installed correctly and in good shape? | |
10-03-2011, 01:44 PM | #1542 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
Will do it again and see. No they have a season on them. Nope both used. Yes Recalibrated. Same thing. Anyone wanna buy an fxr and a new 4PL? Last edited by meffie; 10-03-2011 at 01:51 PM. |
10-03-2011, 02:04 PM | #1543 | |
Rock Crawler Join Date: May 2011 Location: SoCal
When you get a Hotwire, set the braking option at the bottom of the menu to "F/R" to get rid of the delay. Okay, it can be done with button pushes, but Hotwire is way easier. | |
10-03-2011, 02:10 PM | #1544 |
| Could be a binding issue or one FXR is worn out compared to the other. Properly setting up dual ESC's is not for the impatient. It takes time and some skill to get it all correct. Your issue is not in the radio as long as you have everything set at 100% when programming.
10-03-2011, 02:21 PM | #1545 | |
I will check braking option again though. Thanks | |
10-03-2011, 02:23 PM | #1546 |
10-03-2011, 03:55 PM | #1547 | |
As to the "reverse delay", as mentioned, there are a few options with most newer ESC's, one has a delay between "forward" and "reverse". This is why I did one ESC set-up and then copied it to the other ESC. Are you running the same tooth pinions on both motors?? | |
10-03-2011, 04:02 PM | #1548 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
10-03-2011, 04:39 PM | #1549 |
10-03-2011, 05:23 PM | #1550 | |
Got it reset, Thanks | |
10-03-2011, 09:48 PM | #1551 |
Ok so I know you have to be tired of me, but here's my last ditch effort. I reset the radio, reset the esc's, plugged in the hotwire, reconfig'd everything. Bound the esc's to the radio. Everything works perfectly and as it should, but the throttle lever is still reversed. Reverse = Forward and Forward = Reverse. If I change the throttle option on the radio to reverse, the motors spin opposite and it creates other issue's. Is there a different setting then under the throttle menu to get this to switch? If everythings wired as should be, which no one seemed to have an issue with my pic, why is the input backwards? Thanks again Last edited by meffie; 10-03-2011 at 09:53 PM. |
10-03-2011, 09:59 PM | #1552 |
Newbie Join Date: Jun 2007 Location: LA
| Channel 2 and 4 needs to be reversed
Hello, From what I read in your last post, you need to reverse the throttle on channel two and channel four. Sounds like you only did it to channel two. Go to the throttle screen and set it to reverse and then go back a screen and set up channel four to reverse. I just got the same set up a few weeks ago and was running into the same issues you have. I still have one motor slightly engaging before the other. Hope this helps. |
10-03-2011, 10:14 PM | #1553 | |
10-03-2011, 10:17 PM | #1554 | ||
However...Why do I keep having however's? LOL Now the rear motor is slower than the front, but only in forward. Reverse they are the same speed. It's almost like there's just some stall going forward. This is under light throttle, too hard to tell on full throttle. It almost seems at full throttle they are the same, but I hate to make that statement without a way to tell for sure. | ||
10-04-2011, 06:59 AM | #1555 | |
10-04-2011, 07:20 AM | #1556 |
| +1, if they have any timing in them (but 1 is reversed as it should be in a MOA) you will get different motor speeds. Most motors, unless ordered as a pair for a MOA, have some timing in them. This is fine until you reverse one motor. Then instead of "advanced" timing, it's actually "retarded" timing when both axles are driving the rig in the same direction. When in doubt, set both to "0" for now. |
10-04-2011, 07:58 AM | #1557 | |
How do I set the timing? Is that a physical thing in the motors? | |
10-04-2011, 08:12 AM | #1558 | |
There are physical marks on the cans that line up with a mark on the end bell. You can set them to zero timing to make sure that is not the issue. | |
10-04-2011, 08:21 AM | #1559 | |
I'll let you know how that goes | |
10-05-2011, 09:53 AM | #1560 |
| While I assume this isn't Zero, not sure which side is, they are both timed the same it appears. Is there still a need to set them to Zero? |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/277689-futaba-4pl-setup-tips-tricks-help.html | ||||
Futaba 4PL - Modelbouwforum.nl | This thread | Refback | 11-08-2011 05:06 AM | |
Scaler Radio Help - Radios & Servos @ URC Forums | This thread | Refback | 11-02-2011 02:46 PM | |
e-Modelismo - Maior Comunidade de Modelismo em Português - Ver Tópico - Futaba 4PL | This thread | Refback | 10-27-2011 03:41 PM | |
Futaba 4PL 4-Channel 2.4GHz SFHSS Transmitter/Receiver - RemoteD - Fjärrstyrd Hobby | This thread | Refback | 10-24-2011 03:51 AM | |
Futaba T4PL - Elektronik - rockcrawler.de | This thread | Refback | 10-11-2011 04:01 AM | |
4PL Dual ESC - YouTube | This thread | Refback | 10-09-2011 08:27 AM | |
ZONACRAWLING • Ver Tema - emisora 4pl | This thread | Refback | 10-05-2011 04:42 PM |
