09-18-2011, 06:25 AM | #61 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
Dude, it thermals on a 55t reedy, a 35t brood, and any other motor besides a brushless. Oh, and why the heck would I put a fan on an ESC that is going on a scaler. Last edited by JesterSpec; 09-18-2011 at 06:28 AM. |
09-18-2011, 06:56 AM | #62 | |
For anyone else on here with issues with the V2/SCT, I'm just trying to see if we can come up with any answers. This is why I was asking about the "C" ratings of packs. It may be that a lower "C" rating is enough to push a marginal design over the edge & cause it to thermal. For anyone else with issues using this ESC, what "C" rating are you using?? | |
09-18-2011, 08:10 AM | #63 | |
Pebble Pounder Join Date: May 2009 Location: Northern Virginia, USA
09-18-2011, 08:18 AM | #64 |
| My guess is, the motor & ESC want more power than the pack can provide (related to "C" rating & mah) which underdrives the ESC causing heat. Similar to what happens when you run a motor outside of the ESC turn limit, you overwork the ESC causing heat. So, a simple experiment, for those with the overheating SCT/V2 ESC issues would be to run a pack with a higher "C" rating (or higher mah) and see what happens. Yes, the ESC should work just like the original versions, but they don't. Yes, everyone that has the issue has a reason to be pissed. |
09-18-2011, 08:32 AM | #65 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
Mine has thermaled with a 1300 40c Fly Sky.
09-18-2011, 08:52 AM | #66 |
09-18-2011, 12:33 PM | #67 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
35c cbp 3s 1300 25c gen ace 450 65c Thunder Power 2200 30c turnigy 1300 I still think it is nothing the end user is doing and solely a problem with the speedo. Some work great as they should and others just don't work right. | |
09-18-2011, 03:53 PM | #68 | |
I feel you have a right to complain. While I can't offer a positive reply, I can only state my sons dual SCT's work and my MM's work on 3S for dual ESC's. | |
09-19-2011, 10:43 AM | #69 |
I'm beginning to feel that Castle products have gone down the tubes these days. Not only do I have a malfunctioning SV2 but now one of my BRXLs took a shit. It worked fine last night and this morning it has no motor output anymore. What causes that? I've swapped motors and ESCs and I've metered the output from the board and there's no power being feed to the output wires. I'm tired of these issues. Do Tekin users go through this kind of problems? |
09-19-2011, 05:35 PM | #70 |
brxl doesn't have a thing to do with castle.
09-19-2011, 05:54 PM | #71 |
Rock Crawler Join Date: Jul 2008 Location: River Falls
Ok.. I just ran my 2.2 KOH'er for a solid 50 minutes on 3S with an SCT Sidewinder and had no thermal issues..Running a 13T brushless, 87/20 48P gearing and the ESC is med-warm to touch (with no temp guage I gotta guess around 100-110 degF). The ONLY time I ever had it thermal was when I had it in my DF03 rally truck geared too tall (78/15) with sticky 1.9 Flat-Irons..I switched to an 83 spur and put a fan on the ESC and no more probs...
09-19-2011, 06:01 PM | #72 |
09-19-2011, 06:02 PM | #73 |
hmm... holmes hobbies contracts someone I'm sure. I really doubt its Castle...
09-19-2011, 06:10 PM | #74 |
09-19-2011, 06:26 PM | #75 |
wow... Go tell that to John Holmes...
09-19-2011, 06:38 PM | #76 |
Rock Crawler Join Date: Aug 2009 Location: Sandy Oregon
Have you tried updating the firmware to that ESC? I had a SCT that wouldn't even run a brushed motor till I upgraded the firmware...now all is good.
09-19-2011, 06:46 PM | #77 |
09-19-2011, 06:47 PM | #78 |
not to attack you, but your a dumbass. I own one, and have read many times John say that the similarity between his esc and the Castle's are the case, and that is all. Go back and hide in the hole you came out of. |
09-19-2011, 06:51 PM | #79 |
You're incorrect..Why area you acting like a dick..Why do you think it uses Castle software and Castle link. Do you think Castle would allow that if there was not contract between the 2 companies. The BRXL is not a Castle ESC, Holmes designed it but Castle manufacturers it for him.
09-19-2011, 06:55 PM | #80 |
Sounds like you guys are overheating, never mind your ESC's..
