09-15-2011, 09:43 PM | #41 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
If your stll running the 27t, just cut the tab on the end bell and back the timing off 12° or so. If its not one of those flat sided cans.
09-16-2011, 03:48 AM | #42 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
09-16-2011, 09:24 AM | #43 |
Pebble Pounder Join Date: Mar 2006 Location: Paradise
09-16-2011, 11:11 AM | #44 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Well you definitely aren't the only one having problems. I tried 6 different controllers for my moa (sv2) and they all did the same thing as the rest describe. I can put in other speedo combos and the issue goes away. Also I can take the speedo in question and put it in other vehicles and it will o the same thing. I have been working with a very helpful gentleman there named Joe Ford. I recommend if you are having problems also to contact him and let him know. They are semi aware of the problems and are working on a solution for us. Here are a couple other threads with the same issue Opinion on dual Sidewinders for XR10 Electronic problem |
09-16-2011, 01:54 PM | #45 |
Is the motor hot as well or just the ESC? Try dropping a couple teeth on your pinion if the motor isnt hot, that may help reduce temps at the ESC. I am running the Sidewinder V2 with the same gearing you are but I am running a 1.9 scaler so its a bit different. I am going to go out on a limb and say that the sidewinder isnt really up to comp crawling specs. In my opinion it is much better suited for scale trail running and crawling (not ttc or anything like that). My esc gets good and warm but I have yet to have it get super hot. For comp crawling its really hard to beat the FXR as far as both size/weight and performance, the price isnt that much more than a sidewinder v2. |
09-17-2011, 08:15 AM | #46 | |
09-17-2011, 09:06 AM | #47 |
Well I understand everyone frustration, their specs should probably be altered to reflect the issues with hard running on 3s. At the same time you cant buy their entry level esc and think that it will perform as well as higher end (and higher cost) esc's. Has anyone thought of/tried putting a fan on it? |
09-17-2011, 09:14 AM | #48 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
09-17-2011, 11:08 AM | #49 | |
Everyone reading this, save your money and get an fxr or br-xl or if you can find an old v1 scoop that up and use it. | |
09-17-2011, 11:26 AM | #50 | |
09-17-2011, 12:56 PM | #51 | |
We do run CC 10A BEC's. I wonder if the "problem" ESC's were fed 20C packs??? | |
09-17-2011, 02:43 PM | #52 |
09-17-2011, 07:01 PM | #53 |
| Ummm...my statement was steered towards that "maybe" the V2's/SCT's have an issue with lower "C" packs (like below 35C). Since our house runs 35C+, maybe that is part of why we have no issues. Then again, maybe we have a "good" batch. You seem to support my theory, not dispel it. Your turn...... |
09-17-2011, 07:16 PM | #54 |
Sooo, If an SV1 can run my lipo's, I would think that they sv2 should do it better.
09-17-2011, 07:17 PM | #55 | |
09-17-2011, 07:41 PM | #56 | ||
I have two of them I am running on two 1.9 scalers and I havent had a problem with them running 3s for a couple hours at a time. The esc does get hot but not hot enough to thermal. Call Castle and see if they can help troubleshoot it or replace it if that is necessary. | ||
09-17-2011, 08:06 PM | #57 |
Jester & highland, I'm just trying to see if we, as a community, can add to the troubleshooting. One step is what "C" rating the ESC's are seeing, NOT what worked on a different version of the ESC. As I stated, maybe we have a "decent" batch, or, maybe it is dependent on other factors. If you know the issue (in fact, not your "idea") than put it forth. Otherwise, yes there is an issue that is unresolved but guessed at. |
09-17-2011, 08:13 PM | #58 |
What I got as a fact, was blown off by castle. That is what has me peeved. I'm not an electrical engineer. I'm not going to troubleshoot a piece of equipment that there shouldn't be anything wrong with, and this is what castle wanted me to do. I told them what it kept doing, I told them everything that I knew, they wanted me to reinstall it, and continue to run it and try different things. I'm not going to do that... I'd rather buy something that works instead of trying to fix someone elses problem. I want them to figure out what the hell is wrong with it, and I suggested that. They answered, "we wouldn't know where to look"... Hmm. and I would? |
09-17-2011, 08:41 PM | #59 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
I have to say, that's a piss poor answer . I had an SV2 thermo in less than ten minutes in a 1.9 scaler. When I installed an SV1 in the same rig and changed nothing else, the problem disappeared...
09-17-2011, 08:44 PM | #60 |
I would be that it just isnt up to the power of the 7t puller. Holmes lists 45a continuous for 3s and the sidewinder is rated at 55a continuous full throttle operation with airflow and a 19t limit. Check it out here:https://docs.google.com/leaf?id=0Bxz...thkey=CLGkkq0B Since our top speeds arent very high we probably dont have the airflow hence the overheating. Try a fan, I think that will do the trick. A ton of guys with the SCT version have to put fans on them to keep them from overheating, probably a similar situation here. For compariason a BR-XL is rated 80a continuous with no 540 motor limit. Last edited by SMR 510RR; 09-17-2011 at 08:47 PM. |
