Thread: Balloons...How Reliable are they for WP?
Old 01-02-2012, 05:53 PM   #1
Default Balloons...How Reliable are they for WP?
Here is my dilemma , I have a MMP ESC and I'm using it on one of SCX10 rigs with a New Bright JK body. I don't have room for a RadioShack project box so I'm trying to figure out another way. I'm not worried about really running under water but need some pretty good splash protection. Anyone else have any ideas. I don't want to plasti dip the ESC. Any help would be appreciated. Thanks
AsILayDying is offline   Reply With Quote
Old 01-02-2012, 06:35 PM   #2
Default Re: Balloons...How Reliable are they for WP?
A balloon should be fine for splash protection.
Stregone is offline   Reply With Quote
Old 01-02-2012, 06:45 PM   #3
i balloned my esc and receiver and it held up good. i went under alot of water and it never failed. ran it that way for a good 8 months
PhantomRS10 is offline   Reply With Quote
Old 01-02-2012, 06:49 PM   #4
dezfan's Avatar
I balloon my electronics and zip tie the neck around the wires. I then add another balloon over the first and tip the neck again making sure to stagger the zip ties. Been completely submerged countless times w/o issue.
dezfan is offline   Reply With Quote
Old 01-02-2012, 06:57 PM   #5
Cling wrap is amazing for splash proofing. Balloons works well, but can be a pain. Unplug the fan before you cut off the airflow.
thatguy is offline   Reply With Quote
Old 01-02-2012, 07:10 PM   #6
Non lubricated condoms. Electronically tested, easy to get your ESC into, very tough. I've been using them for years and have never had one fail (in my crawler) . I do have four kids so take my advise for what it's worth.....
War Pig is offline   Reply With Quote
Old 01-02-2012, 07:13 PM   #7
Donkey Punch Champion!
BigBaller's Avatar
Originally Posted by War Pig View Post
Non lubricated condoms. Electronically tested, easy to get your ESC into, very tough. I've been using them for years and have never had...
...do NOT touch any thing Tim builds.
Balloons are good. Condoms are great. I like the ribbed xl's with lots a lube. Zip ties are a must. (on both).
BigBaller is offline   Reply With Quote
Old 01-02-2012, 07:19 PM   #8
Thank you everyone for the replies and putting my mind to rest. But now I feel like I might have some type of ETD (electronically Transmitted Disease) from WarPig. Oh well I guess if you put your truck there expect to come out dirty
Anyways, thanks and now I can go get some thicker balloons and start wrapping.
Old 01-02-2012, 07:23 PM   #9
666
MODERHATER™
666's Avatar
Awww man....washing hands....
Some balloons good, some bad, I've had some crack and split, some too thin, some thick and great!
I have just doubled up sandwich bags and electrical taped the ends with good results.
Sometimes there is condensation though.
666 is offline   Reply With Quote
Old 01-02-2012, 07:24 PM   #10
If you have some silicone sealant or liquid tape you can zip tie the balloon around the wires, and then put a big glob of sealant right where the wires exit(get it all around and in between the wires), and then put another ziptie around the glob of sealant. Highly likely to be submergable, 110% splashable.
Old 01-04-2012, 02:58 PM   #11
Moderator
badhoopty's Avatar
x2. i find magnums are wider and a little easier to get on...
i gave up on finding non-lubricated ones... i havent had any problems with them lubed.
what i really like about them is if you have to adjust a setting on your esc or whatever, you can see the components underneath, and you can easily see if its dry.
badhoopty is offline   Reply With Quote
Old 01-04-2012, 05:30 PM   #12
I have always used condoms too. Easier to get on than balloons. If they are lubed I wash them out and pat dry with a paper towel. Never had an issue.
TexasSP is offline   Reply With Quote
Balloons...How Reliable are they for WP? - Similar Threads
How reliable are summits? nightfiref7efi Traxxas Crawlers 17 09-21-2010 03:30 AM
reliable animal transportation? robbio4422 Chit Chat 6 05-09-2010 04:11 PM
the cloning of old reliable chino63 2.2 Scale Rigs 25 07-14-2006 08:48 PM
How reliable are these things???? PapaPerk General Crawlers 19 01-26-2006 01:27 PM
reliable truck bajabeast General Crawlers 21 07-02-2004 10:55 PM
