01-31-2012, 10:54 AM | #1 |
Rock Stacker Join Date: Oct 2010 Location: canada, bc
| Having some power issues..
Ok so i got a brxl esc, castle 10amp, 7955 servo, 7 turn puller and a 2500 mah 40c 11.1 battery. My problem is that the wheel speed seems to go down with the battery.(like a nimh) The cells on both my batteries are all in good shape. With a freshly charged battery the wheel speed and torque are way higher then say about ten minutes in. Any help would be great... thanks
01-31-2012, 11:17 AM | #2 |
| Re: Having some power issues..
Does the motor or ESC get hot when it slows down? If so, maybe something in the drivetrain is binding? How much charge does the battery take back in? Is the LVC set in the ESC? If so, what is it set to? Your pack description sounds good, so I doubt that is it. Does the same thing happen on any pack you run? |
01-31-2012, 11:21 AM | #3 |
Well a freshly charged 3S lipo peaks at 12.6 volts but tapers down to the mid 11's for most of its charge before it then peters out and hits cut off.
01-31-2012, 11:38 AM | #4 | ||
| Re: Having some power issues.. Quote:
01-31-2012, 02:19 PM | #5 | |
As to the packs, the 2400mah along with the 40C should be fine. What pack connectors are you running? Hopefully not Tamiya's! Do the pack connectors get warm when the wheelspeed drops off? | |
01-31-2012, 02:32 PM | #6 | |
01-31-2012, 03:35 PM | #7 |
i run a 7t puller on of my axials and that thing will kill a small pack rather quickly, when i first got it i tried some 2/3a 1500 packs i had, and it would barely move the rig for about 6-7 min and then the performance would drop, i now ran 2200mah 30c packs and feel the power drop after 15 min.
01-31-2012, 08:26 PM | #8 |
Pebble Pounder Join Date: Mar 2010 Location: PHX
what kind of TX? I was having a similar issue with my BRXL and found that the epa were low on my tx when I was calibrating the esc and tx. |
01-31-2012, 10:09 PM | #9 | |
Having some power issues.. - Similar Threads | ||||
VXL 3s power issues - thoughts? | TwistedXT | Electronics | 12 | 11-22-2011 09:29 PM |
MOA power loss issues. I am stumped. | RickM | Electronics | 13 | 07-24-2011 09:03 PM |
Overheating & Power Issues - SuperRooster + Titan 775 + Huge Tires | jtice | Electronics | 7 | 03-26-2009 03:48 PM |
power issues ? | TLT-ROCKER | Electronics | 4 | 10-10-2007 04:00 PM |
TLT Power Issues | Rob92k1500 | Tamiya TLT Crawlers | 37 | 01-16-2007 03:48 PM |
