04-05-2012, 11:42 AM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: in the 7eventh level of hell
| dual motor esc questions
can a cc sidewinder/ mamba max/ mamba max pro power dual 45t phantom blitz motors. can all of them power the two 45s. i have all three and am trying to finish up my moa build and was wandering.
04-05-2012, 11:51 AM | #2 |
| Re: dual motor esc questions
yes all of them should have lil to no problem running 2 45ts. ive ran 2 30ts on a mmp and a sidewinder
04-05-2012, 01:07 PM | #3 |
thanks for replying. i just didnt know. this is my first moa build and have heard it can be done.
04-05-2012, 03:08 PM | #4 |
since u said you have the 3 escs listed i would use either the max or max pro to keep heat to a min if you are running 3s lipo
04-05-2012, 03:28 PM | #5 |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
| Re: dual motor esc questions |
04-05-2012, 04:02 PM | #6 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
I don't think the sidewinder will be a problem for two 45T's. We have guys in our club running dual 35T's on Mamba Micro Pros on 4s. If size and weight are not an issue than run the Mamba Max, no sense tiying up a nice controller like the MM Pro on brushed motors. If size ad weight are a concern run the sidewinder and just keep an eye on it. |
04-05-2012, 06:10 PM | #7 | |
| Re: dual motor esc questions Quote:
I believe the OP wants to run 2 motors from a single ESC. I would not recommend the sidewinder to run two motors. | |
04-06-2012, 09:25 AM | #8 |
| Re: dual motor esc questions i thought he was thinking the samr with the dual esc. i am wanting to run two 45t blitz on one esc. can the mamba max handle that or will i have to use the pro to pull it off since it seems the sidewinder is out
04-06-2012, 10:13 AM | #9 |
the normal mamba max will handle it just as well as the pro just the pro can handle more than 3s lipo
04-07-2012, 07:54 AM | #10 |
thks guys. you have helpe alot. i was wanting to save the mma pro for my cc 7700kv build anyway. is there anything i need to pay special attention to while doing this dual attemp on my mm?
04-07-2012, 08:18 AM | #11 | |
-"T" the red & black off the ESC to each motor -One motor will be "reversed" wiring so it spins correctly as they need to counter-rotate (if you reverse the wrong one, you can either reverse the ESC, the throttle channel or wiring on both motors) -Set the ESC to "brushed mode" -Make sure you calibrate the ESC to the RX For the first couple of packs, check motor & ESC temps. Warm to the touch is OK, hot is not. Are you going to do dual ESC's or a dig at some point? It will make you happier with the rig if you do. Last edited by Charlie-III; 04-07-2012 at 08:21 AM. | |
04-07-2012, 09:27 AM | #12 |
i have the novak dig i was wanting to use. can i still use it with the single mamba max?
04-07-2012, 10:14 AM | #13 | |
The ESC output goes to the input on the dig, then you go from each dig output to the motors. You still need to "reverse" the wiring polarity to the rear motor so it rotates opposite the front motor. | |
04-07-2012, 10:23 AM | #14 |
There is absolutely no problem running dual 45t motors on a single sidewinder. Two 30t motors is about as fast as I would recommend.
04-07-2012, 11:05 AM | #15 |
what about with the dig. will i have to do anything special or just hook it up and go. thanks for the responce jh. much appreciated
04-07-2012, 11:19 AM | #16 |
04-07-2012, 11:33 AM | #17 |
thanks. missed that one
dual motor esc questions - Similar Threads | ||||
Dual ESC questions????? | MitchellY | Electronics | 10 | 08-08-2011 11:57 PM |
Dual ESC questions. | ComingApart | Newbie General | 9 | 02-07-2010 01:43 PM |
single motor esc or dual motor esc | jwo | Electronics | 0 | 01-20-2010 11:42 PM |
A couple DX3-R Questions.. Dual motor dig? | rbgerrish | Electronics | 8 | 05-06-2008 08:15 AM |
