06-01-2018, 10:12 AM | #61 |
| Re: GT3B battery mod go to lipo
I used a low C lipo from Hobbyking designed for transmitters and didn't do anything special wiht it.
06-02-2018, 12:28 AM | #62 |
Rock Crawler Join Date: May 2016 Location: SoWIs
You could add a lipo protection board, then it would work just like a protected flashlight battery. Boards like linked below are supposed draw ~30uA, which is about 2x the normal self-discharge amount if I'm doing my math correctly. That would only make it 3%/month for a decent battery, and for long term you can disconnect it. The only down side is most have a low limit of ~2.4v, which is quite low for the chemistry most lipo's use. Even so, I'd rather have a lipo drop to 2.4v than to 0v. The best option is probably using LiFE cells w/protection module or NiMH instead. The only real benefit to lipo's over those 2 is weight & discharge rates, cost is actually worse since you don't get as many charge cycles. https://www.ebay.com/itm/3S-20A-12-6...wAAOSw0ThZo98t |
06-03-2018, 08:10 PM | #63 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
Was thinking of getting this https://rover.ebay.com/rover/0/0/0?m...2F162819030839 What are your thoughts? |
07-21-2018, 07:26 PM | #64 |
Got my lipo in my radio, fits so well. I did trim a little plastic bracing off of the screw thingy(top half of right side)to make room for wires. I did get the low voltage cutoff, soldered inline then covering in shrink tubing. Last edited by NitroDarwin; 07-21-2018 at 07:29 PM. |
GT3B battery mod go to lipo - Similar Threads | ||||
FS gt3b lipo question | Elmo | Electronics | 24 | 06-06-2012 11:30 PM |
GT3B Switch Mod | heyok | Electronics | 10 | 04-22-2012 03:25 AM |
DX3R lipo battery mod | hitman46mod | Electronics | 14 | 11-04-2009 04:36 PM |
What Zippy Lipo battery fits a Crawler King? Or whats your favorite 2c lipo battery? | phunkodelic | HPI Wheely King | 20 | 08-31-2009 01:35 PM |
