08-01-2012, 10:28 AM | #1 |
Newbie Join Date: Oct 2011 Location: SO CAL
| FXR Question
I have 2 FXR"S wired together with cc bec . Also have a wantamix . How do I calibrate it? do they need to be seperate? red wires need to be unplugged? Any help would be great! thanks
08-01-2012, 10:45 AM | #2 |
| Re: FXR Question
Calibration has nothing to do with the BEC. It's how the ESC reads the radio signal. The ESCs need to be powered up in order to calibrate them. Do each one individually (it's easier than trying to hit two buttons at the same time and go through all the steps). Prop the truck on a block so you don't run over anything when the ESC that isn't being calibrated runs the motor. |
08-01-2012, 11:31 AM | #3 | |
| Re: FXR Question Quote:
08-01-2012, 11:34 AM | #4 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: FXR Question
Plug in your BEC, disconnect both ESC BEC red wires. Then calibrate each one individually.
08-01-2012, 11:45 AM | #5 |
| Re: FXR Question |
08-01-2012, 07:25 PM | #6 | |
The older version sometimes drifted a bit, the newer one (early this year??) is a bit more stable. I have both versions, the older version is running with dual FX-R's in my 2.2 Bully. | |
FXR Question - Similar Threads | ||||
fxr question | korn_2956 | Electronics | 10 | 02-20-2012 04:41 AM |
dual fxr question | Bukwylde | Electronics | 5 | 06-13-2011 09:51 PM |
FXR question | Wideopen | Electronics | 5 | 03-28-2009 08:24 PM |
FXR question | Shorty40 | Electronics | 4 | 12-08-2008 12:08 PM |
Quick FXR Question | frdtrkguy | Electronics | 6 | 09-26-2008 10:54 AM |
