01-04-2013, 08:58 AM | #1 |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
| 3 racing winch & 3cell
Another dumb question for this fine Friday morning how many of you out there in rcc land are running there 3racing winch on 3cell. and are you doing it through the rx or direct to battery.I did a search but didn't come up with a good solid answer so thanks for any help
01-04-2013, 09:05 AM | #2 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: 3 racing winch & 3cell
ive been running mine on 3s for over a year now..no problems. running power on a small 800mah 3s thru the main control board. as long as your not trying to pull a gang of trucks you'll be good. |
01-04-2013, 09:20 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Im glad you asked this. I purchased a very small 2cell 400mah to run mine. The baby lipo works ok but my rig is a pig and might not allow enough grunt.
01-04-2013, 12:30 PM | #4 |
Thanks ROLANDROCKSHOP for the info. I just got done hooking it up like you explained and it works like a champ 3 cell don't seem to bother it a at all, thanks again for quick reply it is very much appreciated |
01-04-2013, 04:27 PM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: Lyons, MI
I nearly burned my rig down on 3s but it could have been a fluke in the winch controller the pos and neg wires are so close together and usualy loose.. If your going to run a second battery and a lipo at that for the winch put in a lipo cutoff, that little winch can kill a 1050mah 2s in 2-3 pulls you will ruin a battery before you even realize it. Or you could do what I did and run a cc bec directly to the winch controller and set it to whatever voltage works best I have mine @8v and if the battery gets too low LVC on my esc kicks in Last edited by Diesel-tech; 01-04-2013 at 04:30 PM. |
01-05-2013, 07:42 AM | #6 |
Are you guys having luck with the stock winch controller on 3S?
01-05-2013, 08:00 AM | #7 |
thats all ive run my winches with..(4 of them) on 3s,stock board. like i said as long as your not trying to do a chain gang pull it will be fine. and yes,a lipo cut off wouldnt be a bad idea. |
01-05-2013, 09:51 AM | #8 |
I haven't run mine long enough to know but well say I'm not that impressed with 3 racing controller looks a little cheap but looks some times are deceiving. Do you got some thing better? I have been to your site you got some cool stuff there but looks like mostly for servo winches and I'm really not ready to go to a servo winch yet.
01-05-2013, 10:20 AM | #9 | |
| Re: 3 racing winch & 3cell Quote:
To see more details about the various controllers, the link in my sig will get you to a thread about each product. For you guys that want to run 3S, my relay output controllers will get the job done. | |
01-05-2013, 10:59 AM | #10 | |
Quarry Creeper Join Date: Jun 2011 Location: Rainier
I run the Heyok controllers on my 3racing winch and it works great | |
01-05-2013, 11:03 AM | #11 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
Any body know how (or could test) much current a 3r winch draws?
01-05-2013, 11:03 AM | #12 |
This is what I meant about how I can package them: |
01-05-2013, 11:13 AM | #13 |
Quarry Creeper Join Date: Feb 2011 Location: Las Vegas 89121
| Re: 3 racing winch & 3cell |
01-05-2013, 11:23 AM | #14 |
So you don't need a separate battery for winch with this setup it runs though the rx with the addition of a bec powring the rx of course?
01-05-2013, 11:25 AM | #15 |
Might as well post links... The one I pictured runs from a max of 6 volts and gets its power from the receiver connection. The controllers in the last two links can run more than 6 volts. Winch Controller for Radio with Three Position Channel Winch Controller for Radio with 2 Position Third Channel Higher Voltage Winch Controller Relay Driven - External Power - Winch Controllers |
01-05-2013, 11:30 AM | #16 | |
01-05-2013, 11:31 AM | #17 |
01-05-2013, 11:44 AM | #18 | |
Darn it any how more stuff to buy trying to keep this thing on cheap side but theres always a must have goodie comes along lol. keep one of those babies warm for me. I will be buying one from you in a couple weeks - payday of course. | |
01-05-2013, 12:06 PM | #19 |
01-05-2013, 12:37 PM | #20 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
Al, Check your email. I want to add a few more of these options to the store. Last edited by Locked Up; 01-05-2013 at 12:47 PM. |
3 racing winch & 3cell - Similar Threads | ||||
3 racing wireless winch control amp draw | dmgriff266 | Electronics | 3 | 07-26-2012 12:58 PM |
3R racing winch handle 3cell lipo? | NMLJ | Electronics | 16 | 07-13-2011 08:21 PM |
Hot Racing wheels,F&R hubs,& shock weights with pix | spoo76 | Losi Micro-Rock Crawler | 32 | 07-07-2011 09:31 PM |
3Cell Lipo vs. 2Cell Lipo & Heat | Chappy | Team Losi Comp Crawler | 2 | 04-06-2010 05:54 PM |
powering a 3 racing winch , servo & receiver | Badd | Electronics | 1 | 07-28-2009 05:31 AM |
