11-23-2013, 01:29 PM | #61 | |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Why brushless (inrunner) motors aren't best for crawling Quote:
11-23-2013, 01:32 PM | #62 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Agreed that a good radio can make a difference in a lot of areas..Im just now getting around to using my old DX 3.0 to use on my scx10.
12-02-2013, 02:42 AM | #63 |
Trying to sum this up... For our typical need of smooth controllable operation with good torque at low speed, and functional drag brake: * Brushed motors are always good. * Brushless motors have a tendency to cog and free coaster that can be substantially reduced by... - ... gearing down, - ... have a sensored motor, and - ... have more poles. I use a cheap sensored 2-pole inrunner, and it does cog a bit. Using the lowest gearing available does help. Drag brake is not an issue with worm drives. I plan to get a Revolver S within half a year, and expect great improvement... |
02-25-2014, 11:41 AM | #64 | |
Pebble Pounder Join Date: Jul 2013 Location: England
@John Holmes: Many thanks for your extremely informative reply above Could you answer an question?... In my SCX10 (87T spur/14T pinion), I am currently running my Novak Ballistic 13.5T sensored brushless motor on a crappy 45Amp Hobby King XCar ESC (but hey, it is good for the price), because I blew up my Novak Timbuk2 (don't ask!). I found this thread as I am looking for the best ESC to give me the best possible low speed control (sensored brushless). You said... Quote:
Thanks in advance P.S. I appreciate that a higher turn motor would give me less RPM/volt and thus help with low speed control, but I wasn't thinking about that when I purchased it last year. Doh! Last edited by 4WheelRC; 02-25-2014 at 11:57 AM. | |
02-27-2014, 03:39 PM | #65 |
Newbie Join Date: Jan 2014 Location: Carlton
Just wanted to throw out that I am running a tenshock sc411 3500kv in my twin hammers which I do crawling with and some bashing with. On stock gearing this thing will snail crawl and the torque is unreal. It is a sensored 550 4 pole motor. I waterproofed it and am running a tekin rs pro that is waterproofed as well...so far so good. No Issues. I run mine on 2s...3s is out of control fast in this rig without gearing down. I have ran mine through 4-5 inches puddles/creeks. Completely submerged scares me and have not tried it yet. It will snail crawl if when the esc is set properly. I have found that the 550 motors do not like advanced timing. so I run mine on 0 timing and it is incredible. |
02-27-2014, 07:42 PM | #66 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
This is/was interesting thread. I too dislike the freerolling disadvantage. In 1:1, compression braking is nice. Compression braking + gearing reduction is even better. So I just built a big h2 and i used my mmp, roc412 1200kv, a 2speed ax2, and 6/66 gearing on 3s. When this motor/gearing is in my crawler(wraith trans reduction like 2.6) i have the freerolling issue. Not terrible but its there. However when the same setup is in the h2 and in low (like 4.8 ), i can creep the heavy h2 like a brushed motor down a steep slope with great control. When it is in 2nd gear the drag brake will slip slowly down a slope and it is set at only 40%. At the end of the day, the trans reduction is the difference. It also makes me wonder why people seem to hover around 4:1 to 7.5:1 with a 3000kv+ motor and never go any deeper. So ya, if you want to downhill a sensored inrunner as good as a brushed motor, get the deepest gearing. In my experience, the 2.6 axial trans wont do it. Anyone know what the true gearing of a summit trans is? Last edited by 67mustang; 02-27-2014 at 07:46 PM. |
Why brushless (inrunner) motors aren't best for crawling - Similar Threads | ||||
Inrunner/outrunner | Tortuga275 | Electronics | 6 | 12-23-2009 05:13 PM |
Outrunner / Inrunner | WizzRacing | Newbie General | 5 | 05-21-2008 05:24 PM |
Brushless inrunner help. | Scattman | Chit Chat | 7 | 06-29-2007 06:35 AM |
