06-20-2013, 06:39 AM | #1 |
Rock Stacker Join Date: Apr 2013 Location: Van Buren
| Bec ???
Okay...I've got the BEC (CC BEC 6.0V). I'm wanting to go 3s. My rig is the RS10 XT (shutup, I'm having a blast) with stock motors (for now) on 2s 25c, 10 tooth pinions, metal gears, aluminum spur plate, and hardened pins. I'm running the FS GT3C TX with the 3 ch. GR3C RX and I have a micro servo dig switch in the 3rd channel slot. ??? Can I run the CC BEC to the Aux slot on my RX or do I have to run it to the ch. 3 slot? The RS10 has NOOO steering so I love what the dig can give and I'd really like to keep it. Before anyone ask the red + lead on the stock ESC will be removed.
06-20-2013, 06:56 AM | #2 |
| Re: Bec ???
The power rail on most RX's is common, thus the external BEC can plug into any open RX port. |
06-20-2013, 07:02 AM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Bec ??? |
06-20-2013, 11:25 AM | #4 |
Quarry Creeper Join Date: Mar 2010 Location: Yay Area
| Re: Bec ??? |
06-20-2013, 08:56 PM | #5 |
| Re: Bec ???
Thanks for the info guys. That is how I figured it worked. I just wanted to be sure. This is why I love this forum. Straight answers and almost always good information. My allowance for next week will have to go to a STAR purchase. |
06-20-2013, 11:56 PM | #6 |
Newbie Join Date: May 2013
What kinda bec what you use for the servo?
06-21-2013, 01:09 AM | #7 |
| Re: Bec ??? I'm sure you meant...... What bec did you use? It says "cc" so that would be castle creations, and I'm sure its the 10 amp. Last edited by JokersWild; 06-21-2013 at 01:12 AM. |
06-21-2013, 04:31 AM | #8 |
| Re: Bec ??? |
06-21-2013, 07:24 AM | #9 |
I prefer to wire the bec directly to the servo and power the rx with the ESC's bec. Less chances for voltage drop, and you aren't pulling all those watts through the rx for no reason. Either way will work in most cases though.
06-21-2013, 11:09 AM | #10 |
| Re: Bec ??? +1, I always run the external BEC output direct to the servo. My method does NOT involve cutting/soldering, it's a "plug & play". |
06-22-2013, 02:22 AM | #11 |
| Re: Bec ??? |
06-22-2013, 05:55 AM | #12 | |
| Re: Bec ??? Quote:
OKay... Battery directly to the BEC and ESC. Let the ESC power the RX as usual in Ch.2 slot. Send + and - from the BEC to my servos' + and -, and the signal wire from the servo to Ch.1 slot on the RX. If I don't use a Y harness and solder every thing in, what do I do with the signal wire from the BEC? | |
06-22-2013, 06:55 AM | #13 | |
| Re: Bec ??? Quote:
06-22-2013, 07:25 AM | #14 | |
| Re: Bec ??? Quote:
06-22-2013, 08:15 AM | #15 |
06-22-2013, 10:41 AM | #16 |
| Re: Bec ??? |
06-22-2013, 11:42 AM | #17 | ||
| Re: Bec ??? Quote:
No problem. | ||
06-22-2013, 03:10 PM | #18 | |
| Re: Bec ??? Quote:
I would build custom jumper........ This way you have access to changing the bec voltage easily and or swapping servos. Check out pics in post #532 GT3B Hack Question and Answer Thread Last edited by JokersWild; 06-22-2013 at 03:17 PM. | |
06-22-2013, 04:06 PM | #19 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Bec ??? |
06-22-2013, 06:26 PM | #20 | |
| Re: Bec ??? Quote:
Bec ??? - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Castle BEC & Castle Link - not finding BEC | Locked Up | Electronics | 22 | 12-20-2007 03:37 PM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
