Thread: sidewinder sct problem
Old 07-07-2013, 12:02 PM   #1
Default sidewinder sct problem
i have a sidewinder sct that i have ran in my twin hammers for a while now. it is coupled to a tekin ROC 412 motor, running sensorless. i turned it on, nothing different, start-up jingle, but only 2 beeps happened instead of 3, and no finishing jingle. steering and shift servo work, but no throttle. the wires are all in good condition and connected to the motor well. the ground wire is frayed some, but is still attached. so, i dont know if i need a new esc, or what. thanks for your input.
desertmaxx is offline   Reply With Quote
Old 07-07-2013, 07:19 PM   #2
Default Re: sidewinder sct problem
First thing to try:
Center your throttle trim
Check your throttle / brake EPA's (travel) are set at 100%
Calibrate the ESC to your transmitter
If you have a Futaba radio you need to use your servo reversing switch to reverse.
If that doesn't help, here are the LED codes for troubleshooting.
If you are not calibrating and have no throttle input then:
Flashing Red and Yellow = over temp
Flashing Green and Yellow = low voltage cut-off(battery)
Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0.
Solid Green OR Red = should not happen when at neutral, indicates full throttle/reverse
Flashing Yellow = possible problem with controller
Solid Yellow = indicates neutral and armed
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
If you are applying throttle or reverse when NOT calibrating:
Flashing Green OR Red = indicates partial throttle (green) or reverse (red)
Solid Green OR Red = indicates full throttle (green) or reverse (red)
Solid Yellow = should never happen
If you are applying throttle or reverse WHEN calibrating:
Flashing Red and Yellow = should not happen when calibrating
Flashing Green and Yellow = should not happen when calibrating
Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse.
Solid Green OR Red = indicates full throttle (green) or reverse (red) has been read
Flashing Yellow = speed control is not seeing a valid neutral signal, check your transmitters throttle sub-trim is at zero, exponential is set to 0 or linear, and mixing is disabled.
Solid Yellow = indicates neutral has calibrated and is armed
Flashing all colors = speed control is not receiving a valid signal from the receiver. Usually indicates the receiver wire is plugged in backwards into the receiver; also happens when speed control has accepted a calibration setting (throttle, reverse or neutral) and flashes/chimes 4 times before moving to next calibration point; or problem with throttle channel on receiver.
k7zpj is offline   Reply With Quote
sidewinder sct problem - Similar Threads
cc sidewinder sct in scx-10? 4x4 lover Electronics 9 01-19-2012 07:16 PM
CC Sidewinder SV2 vs SCT brazwewn Electronics 6 07-23-2011 06:04 AM
sidewinder sct asw27x Electronics 11 04-24-2011 02:29 PM
Sidewinder SCT BluFalcon Electronics 0 04-13-2011 07:43 AM
sidewinder and sidewinder SCT troubleshooting nstn8 Electronics 7 01-17-2011 07:50 PM
