View Poll Results: What bec voltage ? | |||
Less than 6v | 2 | 1.77% | |
6v to 6.4v | 41 | 36.28% | |
6.5v to 7.5v | 67 | 59.29% | |
7.6v+ | 3 | 2.65% | |
Voters: 113. You may not vote on this poll |
07-25-2013, 06:22 PM | #21 |
Pebble Pounder Join Date: Jun 2006 Location: Keizer, OR
| Re: What bec voltage do you run?
I never bothered to get a castle link, I presume mine is still hat 5.1v to my 7950 th
07-25-2013, 07:28 PM | #22 | |
I run cc Bec's... 1.9.. 6v to my 7950...( its in a mini! Lol.. I only run 2s, so it didn't operate for long at 7.4v nor did it need it in a 2lb 8oz rig.. ) 2.2s.. 7.4v to a 7980... 4lbs 3oz 2.2p.. 7.4v to a 7980... 4lbs 2oz Scx.. 6.4v to a hobbico cs-170 Wraith.. 6.9v(I think) to a 7955 | |
07-26-2013, 02:26 PM | #23 |
| Re: What bec voltage do you run? |
07-26-2013, 03:23 PM | #24 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
Lhs let me borrow his.
07-27-2013, 02:05 AM | #25 |
6.0V. the highest my cheap BEC will provide.
12-08-2013, 05:51 AM | #27 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Im running the 6v the HH BR-XL esc provides..My old school hitec servo (985MG) was only rated for max torque at 6v (177oz/in Tq.)..turns my 1.9s extremely well
12-08-2013, 06:11 AM | #28 |
Newbie Join Date: Jun 2011 Location: South Australia
Servo isn't a HV so it gets 6.0V Will get bumped up once upgraded. |
12-08-2013, 09:05 AM | #29 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
6-7.4v for servos 8-9v for servo winches with heyok controllers. |
12-08-2013, 09:20 AM | #30 | |
| Re: What BEC voltage do you run? Quote:
What happens is you can burn off the traces on the RX PC board if you overload it. This kills the RX. What that limit is, I can't tell you. To avoid this potential issue I only run my external BEC's direct to the servo and let the internal ESC BEC power the RX. The internal BEC's in ESC's are set to allow working through the RX without damage to the RX. | |
12-08-2013, 09:24 AM | #31 |
Quarry Creeper Join Date: Apr 2013 Location: Oroville
I got the RC4wd outcry crawler ESC with turbo 6v BEC. Sent from my NX008HD8G using Tapatalk |
12-08-2013, 09:51 AM | #32 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
7.5v to the Rx
12-08-2013, 10:23 AM | #34 | |
Pebble Pounder Join Date: Nov 2013 Location: HILLBILLY ACRES
| Re: What bec voltage do you run? Quote:
So, you are saying, if a servo is rated to do say, 300oz of torque at 6v. Your best bet is to stay at or below 6v, for optimal longevity of the servo? And if you run at a higher, say , 7.4v. You can run the risk of damaging the servo? Is this right? If this is true, is anyone making a servo that is made for higher voltage? Sorry for the nOOb ?'s.....just trying to get this volt stuff figured out. | |
12-08-2013, 10:32 AM | #35 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
well, since you cant run 7v on 2s, I run 6v on my BEC
12-08-2013, 11:06 AM | #36 |
12-08-2013, 11:22 AM | #37 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
6v because I'm limited by the flysky rx's. would run 7.4 if I rewired or upgraded rx's. |
12-08-2013, 12:03 PM | #38 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
All my servos are rated at 6v so the Castle BEC is set to 6.1 or 6.2v to get an actual 6v out.
12-08-2013, 09:03 PM | #39 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Every servo I own gets 7.4V to them.
12-08-2013, 11:42 PM | #40 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
6v direct to a savox 1231 on the JK. 7.4v direct to a solar d772 on my XJ
What bec voltage do you run? - Similar Threads | ||||
BEC Voltage | Orph3o | Electronics | 3 | 10-25-2012 10:53 PM |
Castle BEC voltage | natskiboy | Electronics | 19 | 05-19-2012 08:10 AM |
Voltage Regulator = BEC? | chiatw73 | Newbie General | 3 | 02-25-2011 06:56 AM |
CC BEC Voltage | t-roller | Losi Mini-Rock Crawler | 10 | 10-27-2010 08:18 AM |
