09-11-2013, 07:28 AM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
| External BEC Question
Okay so I am running the Castle Mamba Max Pro, the Tekin Pro Roc 412 3100kv, and a spektrum dx3e radio and a sr300wp receiver. No since the MMP Has a built in adjustable BEC will I need my external one? |
09-11-2013, 08:00 AM | #2 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
| Re: External BEC Question
The MMP BEC is know for being weak. I use an external on my MMP. If you have one, mite as well use it.
09-11-2013, 09:19 AM | #3 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
If your servo is over 200oz then definately use the external bec. I'd use it even if its not!!!
09-11-2013, 09:38 AM | #4 |
yeah the servo is the 444 oz/in savox one.
09-11-2013, 11:50 AM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
Sometimes i think fools keep their eyes closed while typing this question. The answer is YES! It's ALWAYS YES! A thousand times YES! Never no! Always yes! Cheesh, dam a.d.d. kids.....
09-11-2013, 04:43 PM | #6 | |
| Re: External BEC Question Quote:
Why don't you calm down for a minute, go pull your panties out of a knot in your mangina and learn when not to respond to something that's going to make you upset. Thank you all for your help. Including you douche bag. | |
09-11-2013, 04:50 PM | #7 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
| I always use my external one even if my esc has a built in one, as inexpensive as a new castle BEC is, why not? And you have one u said? So even better! But as stated above, generally anything with a good amount of torque ( 2-300 oz and above) need one and perform alot better. |
09-11-2013, 04:53 PM | #8 | |
Right on. Thanks man. Waiting on the Local shop to get the rest of my crap in from back order to get this all finished. | |
09-11-2013, 05:03 PM | #9 |
Newbie Join Date: Sep 2013 Location: fort collins
I have to say YES! It's ALWAYS YES
09-11-2013, 05:16 PM | #10 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
BEC not only helps the servo but all your other accessories as well and having one allows you to add those other accessories in the future if needed. so as Ireland already put the answer is yes you definitely need one especially with that servo. if you look at the servo rating it will even tell you what voltage to set the bEC at to get the torque you desire. So while mostly related to the servo the bEC does much more things than just support the servo and for $20 you can't go wrong Lik Sent from my SHV-E310L using Tapatalk 2 Last edited by OFFROADRCKOREA; 09-11-2013 at 05:18 PM. |
09-11-2013, 05:51 PM | #11 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: External BEC Question |
09-11-2013, 06:02 PM | #12 |
| Re: External BEC Question Now that's not very nice. Though i understand that name calling is a side effect of the a.d.d. meds. I forgive you. |
09-11-2013, 06:25 PM | #13 | |
Pebble pounder, shut up. This was a valid question being that many of the ESCs today have interanal BECs. I know many post out there exist referencing the need for BECs but not many of them explain them in detail and that confuses people dealing with them for the first time. Im ABSOLUTELY positive you understood all the interals when you began right? And speaking of A.D.D you might need a little yourself being that you cant seem to get your mind off being a complete dick, one on every post it seems, so congrats, your it. LIK | |
09-11-2013, 06:58 PM | #14 | |
09-11-2013, 07:20 PM | #15 |
O im chill bud. Lik Sent from my SHV-E310L using Tapatalk 2 |
09-11-2013, 07:34 PM | #16 |
I'm here to say, Yes.. its always Yes.. even with a brxl set to 6v, especially with a savox... they are amp hungry and want all of they can get. I know from experience when one came on a trade. Savox 1230.. I couldn't get the brxl or a tekin RS to act right. Even after I added the bec, the rig was lacking on full throttle assaults on hill climbs.. I switched it out for a hitec and all issues went away.. (yes, ppl run them without issue and that's awesome!) I haven't had such luck.. good servo for the money, not worth it to not have a hitec. IMO... |
09-11-2013, 07:38 PM | #17 |
09-11-2013, 08:19 PM | #18 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Second if there are "many" posts with the question and "not many", but leaving some, to actually to explain in detail then it sounds to me a lack of searching and re search. I've posted in great detail two times and less detail since leaving it to someone to search. As for the rest of your post...... Meh don't do nothing for me..... But then again I've been rent free for quite some time. As for the info I actually typed it out and decided to delete it, its really the lazyness I see. Internal bec has low amperage..... Designed to support voltage cut down to rx when using large voltage batteries. External bec has many benefits...... Lower esc temps, lower motor temps, actual voltage control at higher amperage. Last edited by JokersWild; 09-11-2013 at 08:22 PM. | |
09-11-2013, 09:14 PM | #19 |
Wait, what's a bec?
09-11-2013, 09:23 PM | #20 |
Rock Crawler Join Date: Aug 2010 Location: Esko
External BEC Question - Similar Threads | ||||
external bec? | hoghead5150 | Axial Wraith | 11 | 11-09-2012 10:40 AM |
External BEC do i need | keithgemmill | Electronics | 1 | 08-15-2010 01:44 PM |
what is with all external bec and would it help me | hpiontherocks | Newbie General | 4 | 04-05-2010 03:41 PM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
External bec | sullysracin | Electronics | 3 | 01-28-2010 08:21 AM |
