Thread: Tekin FXR issues
Old 04-23-2014, 04:03 PM   #1
Default Tekin FXR issues
I can't find any info any where on this, but this is the second FXR system I had, issue is, the motor won't spin unless I give it a turn, and as soon as the motor stops, it won't spin, no matter how long you hold the throttle.
I've cleaned the motor, shaved the commutator and cleaned the brushes, everything runs, but the motor needs to be spun, so I swapped in another new motor, and the same.
My other 2 crawlers also use the same system with no issues.
I'm getting real pissed with this system.
69rd96 is offline   Reply With Quote
Old 04-23-2014, 04:13 PM   #2
Default Re: Tekin FXR issues
Mine done the something,needless to say I don't have a fxr anymore.
JustinM is offline   Reply With Quote
Old 04-23-2014, 04:18 PM   #3
I ain't going back to brushless!
Old 04-23-2014, 04:27 PM   #4
I ordered the CC SV3.
Old 04-24-2014, 06:30 AM   #5
Sounds like a hung brush, but.. Since you swapped out motors and the same thing happened, it shouldn't be the case..
Did you solder the ESC up? Might want to check the solder job at the posts.
If the lights on the ESC are lighting up correctly, it typically isn't the ESC.
I have had a dozen fxr's, easy.. It was the most reliable ESC on the market, smallest, and can handle anything! (That I should throw at it) alot of 4s action..
winnerone23 is offline   Reply With Quote
Old 04-24-2014, 01:35 PM   #6
I'm guessing it's also the motor, I hooked a battery pack direct to the motor and it only spun when I spun the shaft. The other motor did the same.
I also do not use the capacitor with it either, dunno what it's purpose is for, but it has run the same since it fell off a few months back.
Tekin FXR issues - Similar Threads
Tekin FXR PRO issues juswin24 Electronics 11 03-27-2012 09:52 PM
Tekin FXR issues ZackMicF Electronics 43 02-02-2012 10:03 AM
Tekin FXR issues AUSCRAWL Electronics 5 05-26-2011 05:51 PM
tekin fxr brake issues crawler_jake Electronics 2 04-13-2011 10:21 PM
Tekin FXR-Pro Issues jevyguy Electronics 2 11-13-2008 07:41 PM
