Thread: Where do LEDs wire in with bec?
Old 08-25-2014, 07:51 AM   #1
Default Where do LEDs wire in with bec?
I found this diagram but not sure where to tap in with LEDs. Should power go to led controller from bec then to servo?
Its a sidewinder 3 and castle bec. Gt power led kit and stock axial radio.
toddbuff is offline   Reply With Quote
Old 08-25-2014, 08:38 AM   #2
Default Re: Where do LEDs wire in with bec?
I'm thinking leave the power wires going from ESC to LEDs and put power wires from bec to servo and signal wire fro LEDs. Sound right?
Old 08-25-2014, 08:46 AM   #3
Unless you have a high power light bar you can power the LEDs off of a spare channel on the receiver.
I would read this thread first.
How to wire LEDs
Then check out the LED controllers.
HeyOK's RC Electronics items (all in one place)
I use the headlight/brake light which has connects on CH2 and has a pass thru for the ESC signal.
k7zpj is offline   Reply With Quote
Where do LEDs wire in with bec? - Similar Threads
How to wire LEDs heyok Electronics 160 11-01-2022 12:06 PM
BEC into Batt/Bind Plug on 4ch SR410 w/LEDS on TF2? Reqlis Electronics 5 08-16-2013 08:15 AM
Wire for LEDs. Mirage Electronics 3 03-16-2012 07:59 PM
Easiest way to wire LEDs in body AdverseCity General Crawlers 3 01-22-2012 09:03 PM
how do I wire red LEDs so it will light up during braking? ussprinceton2004 Newbie General 0 03-07-2008 05:33 PM
