05-31-2015, 02:15 PM | #1 |
Newbie Join Date: Mar 2015 Location: Round rock
| Electronics issues
I water proofed my electronics the other day and now my rig won't drive. My servo will twitch left to right then get locked up on drivers side. I replaced the esc and that did not fix anything. What do I do Sent from my iPhone using Tapatalk |
05-31-2015, 02:28 PM | #2 |
| Re: Electronics issues
Do-tell... How EXACTLY did you waterproof your electronics?
05-31-2015, 03:36 PM | #3 |
For the servo I used marine grease for the gears then dippers the outside in plastidip , for my esc I dipped it in plastidip as well Sent from my iPhone using Tapatalk |
05-31-2015, 05:16 PM | #4 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
Sometimes when you reassemble the servo incorrectly it will do that. Perhaps there is too much drag on the gears in the servo. You are better off throwing the plastidip away and get some conformal coating. It's what I use, and most of the professional companies are using it standard. Silicone is a widely used type. I get the brush on kind. Plastidip failed on me in every piece i used it on, eventually. Conformal coating has been perfect. check amazon for conformal coating. |
05-31-2015, 06:36 PM | #5 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Electronics issues First, quit adding grease to the gear sets. Puts too much strain on the motor. Wipe it all out and put a drop of silicone shock oil and leave it. Most of the gears wear and self lubricate. Second put a rubber o ring under servo horn to keep out water. The plasti dip sucks but if you want to use it go ahead. Main concern here is adding this un needed stress to servo gears with added grease, this has been covered many times before in the "waterproofing" of servos
06-01-2015, 03:13 AM | #6 |
Another aspect is that most of these coatings are electrically conductive until properly cured. Don't try to use the electronics until the coating is cured all the way through, which can take several days if the coating is thick. |
Electronics issues - Similar Threads | ||||
rtr electronics issues??? | jdoubleu80 | Axial Wraith | 13 | 02-12-2013 03:50 AM |
Electronics issues | losikid | Electronics | 22 | 01-19-2012 08:29 PM |
Stock Electronics issues | KingJerd | Axial SCX-10 | 10 | 11-30-2010 05:11 PM |
issues with stock electronics | PineapplAssasin | Axial AX-10 Scorpion | 10 | 06-20-2010 12:09 PM |
Help, new TTR Tremor but I am having issues....Electronics?? | ScaleHobbies | Tamiya Clod Buster | 0 | 02-22-2005 05:18 AM |
