11-15-2015, 02:50 PM | #1 |
Newbie Join Date: Nov 2015 Location: a house
| Low power reverse
After installing a new ESC recently everything is working properly except my rig has extremely low power when transmitting reverse. If I turn my throttle rim to reverse it has good power, it's only when I use the trigger to reverse that I have the problem. I have tried to re-calibrate with no improvement. I am baffled. Any ideas what could wrong? This is a pretty new rig, everything is still like new. It is a TacticTTX300 Transmitter hooked up to my Axial scx10 Deadbolt
11-19-2015, 12:30 PM | #2 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
| Re: Low power reverse
What esc are you using?
11-19-2015, 01:38 PM | #3 |
many Esc are set to default to have only 50% or so reverse power. especially non crawler or general use EScs
Tags |
#reverseproblems #reverse |
Low power reverse - Similar Threads | ||||
More power in reverse | rippinex | Axial Yeti XL | 6 | 08-28-2015 11:42 AM |
tekin rs only has 50% power in reverse | realsickclown | Electronics | 8 | 08-27-2013 03:28 PM |
Little power in reverse | nuckle | Electronics | 2 | 02-28-2013 08:28 AM |
Reverse power | klausdenmark | Newbie General | 2 | 06-22-2012 04:21 PM |
Is the Tekin B1R "low power in reverse" issue fixed? | GWEEDZ | Electronics | 3 | 05-27-2011 12:50 PM |
