04-18-2016, 09:18 PM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: Missoula
| Bec?
I have searched and haven't found this exactly. I'm sure I've got it, but want to confirm before I buy batteries. I have an HH Trailmaster ESC and HH Servo on the way. The info on the servo states it will operate at a 2s lipo 8.4v max. Can I run 3s lipo and the BEC set to 8.4 will limit that 3s lipo voltage down to what is able to be handled by the servo? Or am I limited to a 2s lipo battery? |
04-18-2016, 09:21 PM | #2 |
Pebble Pounder Join Date: May 2013 Location: Miami
| Re: Bec?
No you're fine with 3s the bec just needs to be set.they come set at 6v usually Sent from my HTC One mini using Tapatalk |
04-18-2016, 09:22 PM | #3 |
| Re: Bec?
If its a powerful servo it's best to get a stand alone bec usually a ccbec. Sent from my HTC One mini using Tapatalk |
04-18-2016, 09:25 PM | #4 |
| Re: Bec?
Yes that is what I have on order is a ccbec as well as the servo. Thank you, that confirms is then.
Bec? - Similar Threads | ||||
BEC | Castle Creations CC Bec 10A 6S Switching Regulator | le varan | Axial Yeti | 8 | 06-02-2015 12:08 PM |
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
