11-03-2016, 02:12 PM | #1 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| hot motor?
Can an inproper spur to pinion mesh cause a brushed motor to be hot to the touch? Where is other areas that should be looked at?
11-03-2016, 02:17 PM | #2 |
| Re: hot motor?
yes, along with any binding in the trans, or diffs...also what ratio are you running with the spur and pinion? If its too high, it will overheat the motor.. ideally you want a ratio between 5.5:1 and 6.2:1 keep your stick on the ice! |
11-03-2016, 02:20 PM | #3 |
| Re: hot motor?
If the mesh is too tight it will absolutely overheat the motor due to increased drag.
11-03-2016, 02:40 PM | #4 |
| Re: hot motor?
Mesh seems loose should have checked it after I unboxed it. Spur is 48p 60t and pinion is 48p 16t. That's stock haven't played with it. Also that's the first red green reference I've seen on here lol loved that show. |
11-03-2016, 02:44 PM | #5 |
| Re: hot motor?
WOW! 60 divided by 16 is 3.75:1...no wonder its hot! try a 10t-12t range to get the ratio down..that will cool the motor off.. yup I love the red green show.... red is fond of duct tape lol |
11-03-2016, 02:46 PM | #6 |
| Re: hot motor?
16 is fine if you're running an 87 tooth spur but not 60.
11-03-2016, 02:52 PM | #7 |
| Re: hot motor?
Well I know what I need to get thanks guys. Need to hit the LHS I'm thinking and 11t will be good it comes out to a 5.45
11-03-2016, 03:17 PM | #8 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: hot motor?
Get a 10 and 3s or 4s Sent from my SAMSUNG-SM-N900A using Tapatalk |
11-03-2016, 03:23 PM | #9 |
| Re: hot motor? |
11-03-2016, 08:06 PM | #10 |
Rock Stacker Join Date: Jul 2015 Location: Terry
| Re: hot motor?
May I ask what this is on? Maybe it is geared like that because it has to compete with vehicles who actually have high speeds. Lol Sent from my iPhone using Tapatalk |
11-03-2016, 08:18 PM | #11 |
| Re: hot motor?
It's in my RGT scale rig, no speed needed it's not a rock racer more of a c1 type rig RGT bronco |
11-04-2016, 05:21 PM | #12 |
| Re: hot motor?
Found a set from 9t to 12t I will be getting soon then I can test which one I will settle for
hot motor? - Similar Threads | ||||
Hot Hot Motor | bigdogs21ford | Axial SCX-10 | 23 | 08-21-2014 03:30 PM |
Motor getting hot | jeepscx10 | Electronics | 17 | 10-26-2013 11:29 PM |
Motor getting hot | pentec | Venom Creeper | 17 | 09-04-2011 02:18 PM |
How hot is too hot for the motor? | Mr. Ed | Losi Mini-Rock Crawler | 4 | 06-13-2010 11:09 PM |
motor temp - how hot is too hot? | wicked4x4 | Newbie General | 16 | 03-18-2010 09:49 AM |
