02-09-2017, 03:28 AM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: Ankeny
| Slow Reverse
I have a Trailmaster BLE Pro and 2700kv Trailmaster Pro. Using this combo in my Scx10-2 rtr with Tactic radio that came with the rtr. I checked the BLE esc with a Castle link and all is at factory default for sensored brushless. Motor wires connected by color and sensored cable connected. Motor runs about half speed in reverse in comparison to forward. Red light for forward on esc responding correctly. Any ideas on slow reverse. I am using fully charged 3s battery. I have contacted John but no reply so far. Any ideas? Thanks in advance.
02-09-2017, 05:13 AM | #2 |
| Re: Slow Reverse
Red on esc is reverse, green is forward. Use castle link and check forward and reverse output, I think reverse defaults at 50% Hang up and Drive |
02-09-2017, 06:50 AM | #3 |
| Re: Slow Reverse
Thanks for the reply. Do l need to change forward and reverse on the transmitter? And the instructions for the esc show holding forward on the transmitter when red light is flashing. Not correct?
02-09-2017, 07:31 AM | #4 |
| Slow Reverse
Yes, that will work. Red light flashing on Tx is binding mode , follow instructions Hang up and Drive |
02-09-2017, 08:03 AM | #5 |
| Re: Slow Reverse
If after reversing the channel you still have a slow reverse, you might want to check if the motor has advance timing on it.
02-09-2017, 09:40 AM | #6 |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
| Re: Slow Reverse
I don't know the default settings on the Holmes controller, but on Castle branded controllers the default setting is for 50% power in reverse.
02-09-2017, 01:30 PM | #7 |
| Re: Slow Reverse
Changed from forward to reverse on transmitter. Can get esc to show storage of forward but can get no reverse to store. What happens if I change motor rotation in esc with Castle link? Any potential damage to anything? And 100 percent reverse is default setting in esc. Haven't solved my original problem yet. |
02-09-2017, 02:34 PM | #8 |
| Re: Slow Reverse
You need to bind first Tx to Rx. Then you need to calibrate esc per directions. Sounds like you bond but not calibrated Hang up and Drive |
02-09-2017, 04:15 PM | #9 |
| Re: Slow Reverse
Radio system is bound. Hold full throttle on transmitter and plug in battery. Esc shows green and then goes to fast flashing red. Hold full reverse on transmitter but can not get reverse to set. And the instructions for the esc mention nothing about a green light when calibrating.
02-10-2017, 05:06 AM | #10 |
| Re: Slow Reverse
With transmitter throttle switch set to normal and not reversed, I can calibrate the esc. Truck goes forward and backward correctly, but still about 50 percent reverse. Castle link shows 100 percent reverse in esc. Any ideas? I can live with half speed reverse. Would just like to know why I have this problem.
02-10-2017, 07:02 AM | #11 |
| Re: Slow Reverse
Like i said earlier, if it is still slower in reverse check the timing on your motor, if it's advanced, it will always spin faster forward than reverse...
02-10-2017, 08:06 AM | #12 |
| Re: Slow Reverse
Brushless sensored motor.
02-10-2017, 08:22 AM | #13 |
| Re: Slow Reverse
..didn' catch that, thought it was a brushed motor......timing in settings maybe? 100% reverse and forward?
02-10-2017, 09:20 AM | #14 |
| Re: Slow Reverse
i just remembered, try also playing around with your throttle trim at idle setting, if it's slightly off it can also make it difficult to program the esc.
02-10-2017, 09:27 AM | #15 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: Slow Reverse
Check the brake curve in the castle link, it also effects reverse.
02-11-2017, 11:00 AM | #16 |
| Re: Slow Reverse
Brake curve is linear just like throttle curve.
02-11-2017, 11:18 AM | #17 |
| Re: Slow Reverse
Reset to defaults, then select reverse power to 100% manually and update again. Sometimes it will not actually change the values.
02-11-2017, 03:03 PM | #18 |
| Re: Slow Reverse
John, Select 100 percent reverse with castle link and recalibrate esc, correct? What version of Castle link should I be using? The latest one? And thanks for the reply and help. |
02-12-2017, 06:32 AM | #19 |
| Re: Slow Reverse
Truck responds correctly as it is, except for red light for forward on the esc and half speed reverse. If I change switch on transmitter, I can get green light when pulling throttle on transmitter. But will have to change to reverse rotation using Castle link on esc. Will reverse rotation hurt sensored brushless motor? Can't believe that I am the only person having these problems. As in half speed reverse, red light for forward on esc. Thanks for all replies.
02-12-2017, 06:44 AM | #20 |
| Re: Slow Reverse
You're not having problems. Reverse rotation is normal for many esc/Tx combinations. Futaba will always tell you to reverse rotation with castle Hang up and Drive |
Slow Reverse - Similar Threads | ||||
slow reverse problem | david37370 | Redcat Crawlers | 2 | 02-23-2013 11:25 PM |
ae1 reverse is slow! | bikerpyro | Electronics | 1 | 06-26-2011 07:20 AM |
slow reverse...? | boosst | Team Losi Comp Crawler | 7 | 06-21-2009 08:11 AM |
HELP! Reverse slow. | MISFITCOMPER | Team Losi Comp Crawler | 9 | 06-03-2009 01:59 PM |
Ax-10 slow in reverse | 8upboyz | Axial AX-10 Scorpion | 5 | 05-12-2009 01:50 PM |
