05-14-2017, 03:36 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| Bec
I bought a hitec 7955tg servo and a mamba monster x esc. the dude at the hobby shop says i won't need a external bec. Is this true or will it brown out like a savox? thanx.
05-14-2017, 03:44 PM | #2 | |
Pebble Pounder Join Date: Feb 2017 Location: US
| Re: Bec Quote:
Sent from my LG-H830 using Tapatalk Last edited by excabswap; 05-14-2017 at 04:43 PM. Reason: Because ep is so awesome | |
05-14-2017, 03:50 PM | #3 |
| Bec
With the MMX the dude told you about the Castle link that will allow you to set your bec at 7.4v? The MMX has the amps so set it up and go. Hang up and Drive |
05-14-2017, 03:52 PM | #4 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: Bec
The mmx has a choice of voltage output to suit all, and a healthy 8A current supply to play with. A castle dedicated bec only has 10A. Looks like you'll be fine.
05-14-2017, 04:11 PM | #5 |
| Re: Bec
Yes I am aware of the castle link and know that castle speed controllers have adjustable internal bec but usually HV servos will brown out. this servo is only 6v so ill give it a shot
05-14-2017, 04:26 PM | #6 |
| Re: Bec
It's not voltage that causes brownouts and glitching, it's the lack of amperage. The MMX has 8a output. Hang up and Drive |
05-14-2017, 04:39 PM | #7 |
| Re: Bec |
05-14-2017, 04:44 PM | #8 |
| Re: Bec |
05-14-2017, 06:14 PM | #9 |
| Re: Bec
Amperage makes sense since most of them brown out when turning and on the throttle at the same time.
05-14-2017, 09:41 PM | #10 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
| Re: Bec Quote:
To answer the original question, you can power a pair of savox servos on that BEC and it will not hit it's current limit. We have run 1/5th scale servos on it without any issue. | |
05-14-2017, 11:44 PM | #11 |
| Re: Bec
Sweet thanx for the info! I'm gonna test out the mmx and a new 1410 3800kv Sensored motor in my yeti tomorrow. Should be sweet!
05-15-2017, 05:13 AM | #12 |
| Re: Bec
Thanks Robert, interesting factoid ! Hang up and Drive |
05-15-2017, 08:53 AM | #13 |
| Re: Bec two servos! , i need to upgrade all of my castle escs, i have about 20 from mamba 25s all the way to mamba max, that's going to hurt the wallet.. |
Bec - Similar Threads | ||||
BEC | Castle Creations CC Bec 10A 6S Switching Regulator | le varan | Axial Yeti | 8 | 06-02-2015 12:08 PM |
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
