07-06-2018, 09:31 AM | #41 | |
| Re: Hobbywing 1080 Setting Chart by JBoucher Quote:
You can do this with the 1080 because the programming card plugs into the fan port. | |
07-06-2018, 10:26 AM | #42 | |
RCC Addict Join Date: Jun 2017 Location: Canada
I might have to glue it there... Sent from my Nexus 6 using Tapatalk | |
07-06-2018, 10:29 AM | #43 | |
A dab of E6000 or Shoe Goo should hold it on and still be removable when needed. | |
07-06-2018, 10:33 AM | #44 |
It came that way from hobbywing. It holds very very lightly in the fan port. Could be the cable but i don't have another one to test it. Sent from my Nexus 6 using Tapatalk |
07-06-2018, 10:48 AM | #45 | |
Jato I wonder, do you see any noticable reduction in run time by keeping the programming card powered up? Any extra heat? | |
07-06-2018, 10:50 AM | #46 |
| Re: Hobbywing 1080 Setting Chart by JBoucher I don't keep mine connected. I was just suggesting to jboucher that he could leave the cable, not the programming card itself, attached to the ESC for ease of access for programming.
07-06-2018, 10:53 AM | #47 |
Rock Crawler Join Date: May 2018 Location: USA
| Re: Hobbywing 1080 Setting Chart by JBoucher LCD screens are extremely low draw, something in the microamp range. Remember in the old days we had these things called calculators, and they would have a tiny "solar" panel that was able to power it via ambient lighting? I know that I personally always use my Venom LVC module and cannot notice any appreciable difference in runtimes, even on my Slash that drains a 2s battery in 20ish minutes.
07-06-2018, 10:53 AM | #48 |
| Re: Hobbywing 1080 settings
Also on leaving the cable attached, a post in the other 1080 thread mentioned having bent the pins because of leaving a cable attached, so a little food for thought.
07-06-2018, 11:01 AM | #49 |
| Re: Hobbywing 1080 settings That was me. My pins bent because I didn't have the cable fixed and it fell off the chassis and got tangled on the tire. Properly attaching it to the chassis should prevent bent pins.
07-06-2018, 11:47 AM | #50 |
OK, I just leave my cable attached to the programming card.
07-06-2018, 11:54 AM | #51 |
| Re: Hobbywing 1080 settings I do too. But during that testing stage when I was trying to get the ESC settings right I left the cable plugged in. It is a nice option to have though when your ESC is in hard to reach spots like on the Bomber.
07-06-2018, 11:58 AM | #52 |
Yeah, next time i open it up, i will glue the cable in there. Sent from my Nexus 6 using Tapatalk |
07-06-2018, 04:46 PM | #53 |
I love the 1080 QuicRun, mine is mounted upside down on the middle of my steel transverse BPC LiPo tray on my Ascender K10 - it's completely out of the way of the suspension. Mounting it like that does make it a little harder to get at, but the weight could hardly be placed any lower... ...and if it gets wet (I know they are listed as waterproof, but still!) the water drains out of where the pinouts are, 'cause - well, it's upside down! Used 3M industrial double-sided sticky tape. |
07-06-2018, 05:42 PM | #54 | |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Hobbywing 1080 settings Quote:
07-06-2018, 08:11 PM | #55 |
| Re: Hobbywing 1080 settings Basically, it's right about where a 1:1 engine would be and all the wiring goes straight up and away - I have no electronics mounted behind it other than the motor in its stock location, receiver & power button are next to servo up front... I've beat all hell outta it and it's holding up fine! 1st photo is from underneath, 2nd is from the front, down low: |
07-19-2018, 08:30 AM | #56 |
Quick question, doesn't having the esc in that position defeat the work of the cooling fins? i mean the esc components are designed as to have warmer air flow upwards and leave the case through the fins? am i wrong? on another note , i just tested my 1080 on the tactical trx4 and the starup power at setting 1 and it was much smoother then the xl5 unit.
07-19-2018, 11:16 AM | #57 |
Well - technically it's at an angle, and airflow while driving reaches it more easily than if it was hiding deep inside the bodyshell anyways... It never gets more than slightly warm to the touch setup the way it is. My Castle Mamba X in my Bomber gets MUCH hotter, and it points upwards. You're overthinking it a bit, my friend - plenty of things in the real world have downward-aimed cooling fins... |
04-27-2019, 03:37 PM | #58 | |
Newbie Join Date: Jul 2016 Location: Milford
So I figured maybe something was wrong with the ESC. Then I tried just running the ESC normally, plugging the ESC directly into my RX and not using the CCBEC / HH bypass and it worked perfectly... So for now I am going to try just using my rig without the BEC and see if the built in one will work out. I am running a Savox1210sg which is only 277inoz at 6v so I don't think it will be a problem with brown out... But sort of bummed because I always run a BEC on my rigs. Also might upgrade to a monster servo 500inoz soon.. I'm using a 3s 20c battery 5000mah. I have looked around and asked several people and still can't figure it out. Any suggestions? | |
04-27-2019, 04:23 PM | #59 |
The 1080 has a beefy internal BEC, no need for more. Sent from my Pixel 2 XL using Tapatalk |
05-21-2019, 02:58 PM | #60 | |
However, I did go back at it and re-installed the CC BEC. The second time I got everything working perfectly and using my HH RX bypass harness. Had zero issues programming the ESC and was a breeze. I also added a winch and more lights so I really wanted it installed. I am now running 7.4V to my servo on the CC BEC and the 1210SG turns into a torque beast. And I can still run the internal BEC on the HW1080WP at 6V so I don't fry my receiver. I wonder if I had a bad solder the first time, although everything was lighting up on my BEC so I don't think that was it. Maybe I was wiring something wrong and it was late at night... | |
Hobbywing 1080 settings - Similar Threads | ||||
Anyone using the Hobbywing QUICRun WP 1080 ESC? | CoolRunning | Electronics | 143 | 04-28-2020 08:48 AM |
Voltage cut-off on Hobbywing 1080? | pullstarter | Electronics | 1 | 02-04-2018 04:13 PM |
Hobbywing 1080 | krazee | Traxxas TRX-4 | 2 | 12-21-2017 09:03 PM |
quickrun 1080 esc settings | allanon1965 | Electronics | 4 | 04-03-2017 10:17 AM |
Hobbywing Quickrun 1080 | triggerhapy | Electronics | 0 | 12-17-2016 01:04 AM |
